Re: Header studs?
[Re: JM67RT]
#449664
08/25/09 04:23 PM
08/25/09 04:23 PM
RapidRobert
studs w the unmachined shoulder between the fine & coarse threads are the best as the shoulder seals real good when it butts up against the head. You can shorten the outer fine thread portion to aid header installation. If you leave enough threads for the nut to fit flush you're good. I also use Permatex #2(my fav) on the threads.
Re: Header studs?
[Re: RapidRobert]
#449665
08/25/09 05:51 PM
08/25/09 05:51 PM
Posts: 21,086 Niles , Ohio
therocks
Niles , Ohio
I got mine at the local parts store.I run like 2 or 3 bolts with my 2 inch TTIs as the studs wont fit.I just antisieze the studs so they wont stick.My kid does the same on his 413 and they have never leaked.Rocky
Chrysler Firepower
