Page 19 of 29 1 2 17 18 19 20 21 28 29
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449470
08/12/10 06:20 PM
08/12/10 06:20 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Did ya get a picture of the Carillo rods you put in it, Or did ya end up using the other ones?
Just curious, didnt get a chance to rear all 600 pages of this post yet, but Im still diggin.
Kasey
Re: It's FINISHED! [Re: 9secondsatellite] #449471
08/12/10 10:21 PM
08/12/10 10:21 PM
USA
Ron Silva Offline OP
USA
That is a Star Vacuum PP. It's the Mini Pump.
http://www.starvacuumpumps.com/
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Moparnut426] #449472
08/12/10 10:24 PM
08/12/10 10:24 PM
USA
USA
Kasey
We had Crower fix the original R&R Rods. They still aren't perfect by my crude measurment methods, but they were use-able. They looked way better.
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449473
08/12/10 10:59 PM
08/12/10 10:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good to hear Ron and like all of your work, looks GREAT!!!! So, are you going to do some shake down runs at Irwidale soon or hit a 1/4 mile track?
Re: ONE DOWN , ONE TO GO ! [Re: Thumperdart] #449474
08/13/10 04:32 AM
08/13/10 04:32 AM
USA
USA
I am going to try and change the trans before I run it at the track.
Drove it today for about 30 minutes and so far, so good. I just can't get over how quiet and smooth this motor is. This is one of those cars that is decieving
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449475
08/14/10 10:20 PM
08/14/10 10:20 PM
USA
USA
Kasey, here is a pic in the chassis.
I put about 30 minutes drive two times and still have not stood on it. I have probably been 1/2 throttle and 4000 RPM and it feels good/promising. Next time out I will stand on it and then change the oil after that to see what is going on. No strange noises and oil pressure is good except at idle it is kind of low. 18-20 PSI. It has Comp Cams Break in oil 10W30 right now.
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449476
08/15/10 01:05 AM
08/15/10 01:05 AM
Australia
gg408 Offline
gg408  Offline
Australia
Very nice looking setup.
If I could ask were did you get your alternator and brakets from?
Cheers
g408
Re: ONE DOWN , ONE TO GO ! [Re: gg408] #449477
08/15/10 03:08 AM
08/15/10 03:08 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
It looks like a Jones Racing Products kit to me George
AL....
Alan Jones
Re: ONE DOWN , ONE TO GO ! [Re: gg408] #449478
08/15/10 11:51 AM
08/15/10 11:51 AM
USA
USA
Cheers
g408
I ordered that bracket from KRC Power. I am not using it as designed though. It is designed to have the alternator on the front side of the bracket to lineup with a "drive pulley" that would be FRONT of the water pump shaft.
So, I did modify it and if you look close you can see what I did. Copy and paste the pics on your PC and then you can zoom in. The lower front side is MILLED to clear the fan belt, the front side right where the water pump pully is had to be milled slightly to clear the water pump pulley. I just plunge cut with an end mill in a drill press a bunch of times until the metal I need is all removed.
There is about a .250 spacer behind the bracket for alignment purposes. The water pump pulley is a mid to late sixties small block single groove pulley and I think if you took the spacer out it may align with the early 70's small block water pump pulley.
Here is a link and a pic from another angle so you can see what is going on.
Ron.
http://www.krcpower.com/catalog_i6511685.html?catId=353136
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: gg408] #449479
08/15/10 11:57 AM
08/15/10 11:57 AM
USA
USA
Cheers
g408
Alternator is a 93MM Denso that is sold by Powermaster and Summit carries them. Don't let the 93 MM confuse you. The Mounting bracket is made for this alternator that has 138MM center to center measurment on the mounting lugs (you can see this on the link provided). 93MM is the case size.
http://www.powermastermotorsports.com/denso_alternators.html
Mine is the 8162.
Ron.
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449480
08/15/10 12:05 PM
08/15/10 12:05 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Looking at your crank trigger...did you just put magnets in the ATI damper instead of using a separate trigger wheel?
Re: ONE DOWN , ONE TO GO ! [Re: Devilbrad] #449481
08/15/10 12:12 PM
08/15/10 12:12 PM
USA
USA
Yes. That is an option that ATI offers. But I am pretty sure the balancer outer ring is different so the magnets can be installed. So, you can't just add them to any balancer without changing the outer ring. This is something that Ryan suggested we do to simplify things and I like it.
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449482
08/15/10 12:58 PM
08/15/10 12:58 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
"Trailering's TOO much WORK!"
This is funny because the one thing you are not afraid of is work!
I have enjoyed watching your craftsmanship, thanks for taking us along for the ride.
Bill
Re: ONE DOWN , ONE TO GO ! [Re: 340Cuda] #449483
08/15/10 11:25 PM
08/15/10 11:25 PM
USA
USA
Well, I finally punched it this afternoon. Lets say I am very happy. You can never really tell (without going to the track), but I would say I will meet my performance goal. It feels faster than the Demon was.
I went to about 2500 rpm rolling in first gear and then hammered down. I am pretty sure the shift light (6000RPM) was on before I even got the throttle all the way open. Of course I had to do it a second time. That kind of power is intoxicating
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449484
08/15/10 11:46 PM
08/15/10 11:46 PM
ohio
all spooled up Offline
ohio
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449485
08/15/10 11:49 PM
08/15/10 11:49 PM
oregon
greendart408 Offline
oregon
Good to hear Ron Just curious is your vac pump staying dry???
Re: ONE DOWN , ONE TO GO ! [Re: greendart408] #449486
08/16/10 12:04 AM
08/16/10 12:04 AM
USA
USA
I think it's too early to tell. So far I have about an hour+ of easy street driving and 2 quick squirts through 1rst 2nd and into 3rd at full throttle. Plus I adjusted the regulator twice. But all is well so far. I will let you know if I find oil. That breather has 2 perforated screens and some coalescing material in it and I doubt much oil will pass through it.
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449487
08/16/10 12:06 AM
08/16/10 12:06 AM
USA
USA
sec
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449488
08/16/10 12:06 AM
08/16/10 12:06 AM
USA
USA
3rd
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449489
08/16/10 12:07 AM
08/16/10 12:07 AM
USA
USA
I am getting real good vacuum with that pump. I actually backed the regulator down for now so I only have 7-8" crusing around at low speed. It was 12-13. Not sure what it is when I stand on it.
SRT DEMON ONE SEAT
