Page 4 of 29 1 2 3 4 5 6 28 29
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: B3422W5] #449170
09/02/09 07:08 PM
09/02/09 07:08 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Ron's custom 48* INDY RP heads will be here Friday..... will be first set I've seen. I'll post some pics when I find time Saturday or Monday. Will be Racing Friday & Sunday. (hopefully)
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: B3422W5] #449171
09/02/09 07:33 PM
09/02/09 07:33 PM
USA
Ron Silva Offline OP
USA
Soooo, 500 cube small block Mopar is possible, and yet, I have never heard of anyone building one!
My only question after seeing this post is why has nobody ever built one before now? Why is this all of a sudden common knowledge, yet I have never heard or seen anything even close to that in a sbm before now.
Ron's old motor was 474 inches..... INDY sells a 471" Kit now off shelf....
All it takes is a big crankshaft. Most guys doing SB Mopars are not willing to spend the $ to be honest.
However, a 4.5" crank in a SB package will not really be a great "race motor" combo (it's too much stroke IMO) That's really why no one has done one.... It's unusual to spend this kind of $ on a motor that will not be a max effort deal.
The 4.25" crank would be as big as I'd go for a race motor that needs to turn RPM & make big power.
The journal overlap on this 4.5" will be scary with 2.0" rods.
Good points...
I know of a guy who went from roughly 400 inch smallblock to 450 inch smallblock, and because of the heads(230 indy)he has seem very little gain in performance, the car is just harder to hook because of the 4.25 inch crank instead of the 3.79 and 4 inch stuff he used to run.
The 500 inch smallblock is a cool deal, and as a "one off" piece its mighty intriging.
From a practical standpoint there are bunches of ways to get a smallblock to go 10 flat easily on pump gas with way less inches and cost, but Ron has the "cool factor" pretty much sewn up
Even if a motor is head limited it will still build more torque with the added displacement. AND: if you can hook it up it will be faster. My car is going to have excellent weight bias so I think I can deal with the extra torque. I wanted a descent idle and to go 10.00 without straining. I may in fact go back to the 10" TA converter from the current ATI 8" when I put this motor in.
A good example was my 468 W-5 motor put out 435HP on the chassis dyno, but on that same pull it was 660 on tq and that was from the very bottom of the graph and heading down the whole way. In other words they could not measure the torque peak. It was too low. That motor drove bitchen on the street. It was like having a huge electric motor in the engine bay! LOL
Also, nobody said this motor was practical. I will admit it is not. I "did" research other motors before I called Ryan. I seriously thought about building an all aluminum 604 Big Block Wedge or even a HEMI. AND it probably would have cost about the same or even possible less. But I do not want to run 8's and if you do run a 10 flat and open the hood with that big HEMI in there, everybody will yawn. Of course you know even THIS motor could have had a much larger solid roller, big oil pan, vacuum pp, dominator carb and so on to make it even faster. I wanted something different and I wanted a simple unassuming look to the motor. Not sure if I will get that or not......
ALSO: If you do the math this crank is going to have NO OVERLAP. Unless I screwed up on my figures (in my head), this crank is going to be right at ZERO overlap
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Ron Silva] #449172
09/02/09 07:40 PM
09/02/09 07:40 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
After lashing valves in my buddies Hemi Road Runner last night, you do NOT want a Hemi in that Valiant LOL I lashed valves on my Big Block this eve, I think it took about 1/4 the time it did on that Hemi. They are so big they are just a pain to work on.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: B3422W5] #449173
09/02/09 07:47 PM
09/02/09 07:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Good points...
But what I don't understand is, 90% of us never knew this was possible. All the posts about how to get 600hp pump gas small block, and this 500 cube monster or the Indy 471 were never mentioned. I am still amazed its possible. And this post has been an education already.
If I were an engine builder, this would be an interesting area to grow the buisness if you could pull it off in a "kit" form at a better price, than a one time custom one. Its a shame because I just think its a little too late to get after market manufacturers excited about supporting it with products because I believe the market is shifting more toward the 3G hemi's now.
I certainly have a car that would hook it, and would have loved all the weight off the front.
The down side, other than cost, is the heads available probably won't make the hp this should be capable of. I will be real curious to see how this comes along, and I am already
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Ron Silva] #449174
09/02/09 07:55 PM
09/02/09 07:55 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Are you going to have it dynoed before installing it?
I would never rely on a Dyno to get my HP. I have only one way of doing it. Vehicle weight VS MPH. I have never dynoed an Engine and I probably never will.
Of course you might want to look at 60 ft to see if chassis efficiency is there etc. But that will not affect MPH much so you can pretty much use MPH. What I am saying is, in a properly set up car the MPH VS Weight will tell you.
I would only use a SINGLE dyno, to compare two engines, or to compare different mods on a single engine.
So if the car is slow, how will you know if it's the motor, or the trans, or the chassis, exhaust, etc...
I agree, the proof is in the pudding with the ET/MPH.
But if the car isn't fast, it sure is nice to know it's not the because motor...
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: dizuster] #449175
09/02/09 08:20 PM
09/02/09 08:20 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The INDY 471 SB (they call it a 472) kit/complete bracket motor has been listed in their catalog since at least January 2008, as it is listed in my 1/08 Price sheet. It uses a Callies 4.25 crank, Eagle H beams & custom Diamonds @ 4.20 bore.
Some of this stuff you just have to look for....
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449176
09/03/09 12:27 AM
09/03/09 12:27 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think the reason no one has done it is because every one thinks if the motor won't turn 7500 rpm then it ain't right and there ain't no heads out ther to support a 500 inch small block at high rpms so no one builds them.
Personaly I like the idea of makeing 600 hp at a very low streetable RPM. Just a little bark but a big bite
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: HotRodDave] #449177
09/03/09 08:40 AM
09/03/09 08:40 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
This was 4.25" crank SB @ 450 inches with same basic prepped INDY heads Ron will have, it's still making VG power @ 7600, I could have turned this one 7800 with no issues.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: HotRodDave] #449178
09/03/09 09:09 AM
09/03/09 09:09 AM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
There are some W series heads and P7's that would do it no problem.
AL....
Alan Jones
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: LA360] #449179
09/03/09 12:31 PM
09/03/09 12:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A 450 running 7600 RPM is about the same as a 500 running 6800 RPM. I know it could be done but it would be very expensive. Think about the heads an average guy could afford to turn a 500 7500 rpm and still make power, not a bucks down guy, then what I said becomes very clear. Not a lot of cross section available with any readily available head that is even remotely afordable
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: HotRodDave] #449180
09/03/09 01:23 PM
09/03/09 01:23 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I can get 3" CSA out of an INDY head. Probably little more with welding.
Pro Stock/Comp CFE W8 is ~3.25"
Nascar Truck W8 ~ 2.75"
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: HotRodDave] #449181
09/03/09 01:31 PM
09/03/09 01:31 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
gilberto.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449182
09/03/09 11:35 PM
09/03/09 11:35 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Ryan what do you expect it to make power wise. I know Ron will not dyno the motor so it is kinda a moot point but just curious what you think.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449183
09/04/09 12:23 AM
09/04/09 12:23 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I am not saying a max effort W8 won't do the job but what would one of those pro stock truck heads cost complete and assembled with springs nessacary to handle the cam nessacary to turn a 500 inch motor effectively 7500 RPM? That is why no one builds 500 inch SBMs
Of course you have guys like me who would build one in a heart beat if the 500 inch kit was reasonably priced and put a stage 3 eddy on it and have a blast sounding very mild and running incredible times I remember several years ago about Rons demon in a magazine and thinking that is almost exactly how I would aproach building a car if I had the $$$ and and skills but it would be a 68 dart
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: HotRodDave] #449184
09/04/09 01:02 AM
09/04/09 01:02 AM
LA360 Online boogie
LA360  Online Boogie
The average guy isn't going to spring the cash for a custom Bryant crank, so it's a moot point. I don't imagine kits like this appearing in anyone's catalogues anytime soon. JMO anyway
AL...
Alan Jones
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: LA360] #449185
09/04/09 02:35 PM
09/04/09 02:35 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
With all this talk about price, I kinda think we're forgeting that this is a 500" SMALL BLOCK! I'm not sure the word mountain motor and accessable belong in the same sentance.
BTW- What your doing is amazing! I wish you would reconsider the dyno as this is a major milestone for all engine builders out there. IMHO What your doing and the way your doing it needs to be recorded. This is hot rodding history!
-1967 Belvedere II 440/4speed
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: MACDiesel] #449186
09/04/09 03:06 PM
09/04/09 03:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I think Ron is right about the dyno...One could say it made 900 horse, another could say it made 500..if the car runs in the high 9's at the weight he is at, it will be very easy to compare it to other motors on here, output wise, that have been dyno'ed and raced, and make a pretty close comparison, and save him some coin.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: B3422W5] #449187
09/04/09 06:41 PM
09/04/09 06:41 PM
SoCal
Brian Hafliger Offline
SoCal
When you dyno an engine, it's not about 900 HP or 500 HP, and by the way there should not ever be that much difference between ANY dyno #'s no matter how many different dyno's are used!! I'm sure you were exaggerating but that was waaaaaay out there LOL!
I used to be on the anti-dyno band wagon, but I must say doing on a weekly basis, you really learn a TON about engines, oil leaks, tuning, and your able to apply that into the next build.
Most of the time, my engines leave with only minor tuning needed that would have taken alot of trips down the strip. Not to mention that if everthing goes well on the dyno, but not in the car, you can successfully determine what components were changed and usually find the problem very quickly and easily.
It's not for everyone, but I have yet to have ANY of my customers even think they might have wasted money on dyno time.
And I have a long list of very happy customers that will dyno their next build guarranteed!!
If it's in the budget, you simply cannot go wrong with dyno testing.
On a softer note....I'm looking forward to seeing Rons car in action at the track!
Brian Hafliger
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Brian Hafliger] #449188
09/09/09 02:27 PM
09/09/09 02:27 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Ron's 245RP 48 degree INDY heads...I had them put the small exhaust port in these heads as well to help with header fitment.
Basically they just leave extra material on intake face, they just surface intake face of casting just enough to get a sealing surface above the port, you can see raw casting left above port in several of following pics....
Taking some measurements it's aproximately .160" extra, & then they machine pushrod holes at different angle/depth than the 59 head.....
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449189
09/09/09 02:28 PM
09/09/09 02:28 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
48
