Page 3 of 29 1 2 3 4 5 28 29
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Dragula] #449150
08/27/09 11:32 PM
08/27/09 11:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Are you going to have it dynoed before installing it?
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: HotRodDave] #449151
08/28/09 02:07 AM
08/28/09 02:07 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
That thing should be a MONSTER. And i thought the 408,s & 410,s were great combos.Pump gas and 10.00 is the way fly!
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Comp Chassis 2] #449152
08/28/09 02:28 AM
08/28/09 02:28 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Mountain Motors usually have rod ratio's in the 1.4 range, lower in some cases.
Sounds like an interesting project Ron, I hope you have fun with it
AL....
Alan Jones
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: HotRodDave] #449153
08/28/09 05:04 PM
08/28/09 05:04 PM
USA
Ron Silva Offline OP
USA
I would never rely on a Dyno to get my HP. I have only one way of doing it. Vehicle weight VS MPH. I have never dynoed an Engine and I probably never will.
Of course you might want to look at 60 ft to see if chassis efficiency is there etc. But that will not affect MPH much so you can pretty much use MPH. What I am saying is, in a properly set up car the MPH VS Weight will tell you.
I would only use a SINGLE dyno, to compare two engines, or to compare different mods on a single engine.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Ron Silva] #449154
08/28/09 07:51 PM
08/28/09 07:51 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Would you do anything different if a aluminum block was available.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: 68Fastback] #449155
08/28/09 09:13 PM
08/28/09 09:13 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
Ron I met you @ the MATS event and thought your valiant was VERY clean and VERY nicely done. Now you are doing this!?! It is probably one of the cleanest Valiants I have ever seen and now you have even more ammo under the hood. Great car!
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: 512 VALIANT] #449156
08/28/09 09:38 PM
08/28/09 09:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Soooo, 500 cube small block Mopar is possible, and yet, I have never heard of anyone building one! Had I known this years ago, the engine in my Cuda would probably be different. Visions of P5 Hemi heads and 500 cubes come to mind....
My only question after seeing this post is why has nobody ever built one before now? Why is this all of a sudden common knowledge, yet I have never heard or seen anything even close to that in a sbm before now.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Dragula] #449157
08/28/09 09:55 PM
08/28/09 09:55 PM
SoCal
Brian Hafliger Offline
SoCal
My answer is: just how much is this 500" sbm going to cost???? That might be why nobody has done it yet?
Compare that to a 500" BBM and you can quickly see why.
I have to say though, it should be one very neat and original build that's for sure. I'm excited to see what happens...too bad you won't stick it on our dyno Ron, that would be neat to get Dulcich down for a day of pics and a nice Mag spread.
I'm going for a completely different approach with my new engine...it's a 360" W2 headed R1 block deal with 48° lifter bores.
I too hope to go 10.00's but I'll be using race gas. Just thought it would be neat to do 10 oh's in a street-like car and no stroker so I know what it's like to go against the grain
Plus I just don't have that much $$$ to spend on an engine build LOL!!
Keep us updated, we're going to want lots of pics
Brian Hafliger
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Dragula] #449158
08/28/09 09:56 PM
08/28/09 09:56 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Ron's old motor was 474 inches..... INDY sells a 471" Kit now off shelf....
All it takes is a big crankshaft. Most guys doing SB Mopars are not willing to spend the $ to be honest.
However, a 4.5" crank in a SB package will not really be a great "race motor" combo (it's too much stroke IMO) That's really why no one has done one.... It's unusual to spend this kind of $ on a motor that will not be a max effort deal.
The 4.25" crank would be as big as I'd go for a race motor that needs to turn RPM & make big power.
The journal overlap on this 4.5" will be scary with 2.0" rods.
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: 68Fastback] #449159
08/29/09 05:35 PM
08/29/09 05:35 PM
USA
USA
That is a good question. As many of you may know I was in a waiting for an aluminum Block. One that would accept all the production components. Basically a Aluminum R3. But, I have not even heard a peep out of anybody for ages. And I predict it is possible it will NEVER happen the way things are going. So I give up hope.
Yes, I probably would have gone with the callies 4.25 stroke forged Crank with all the lightweight machining and then maybe a solid roller to make up the power difference. But the rods would have been the same (except a .927 pin) and pretty much everything else. No CNC Block lightening would have been necessary (or wanted).
I am very weight conscious and have gone to great lengths to lighten the front of my car. So with this Motor I probably spent about $4000-5000 just to lighten the block (full CNC lighten program), crank, rods, pistons/Pins and he is even doing a bunch of milling on the heads AND Manifold for weight reduction. I think Ryan said the Crank might end up less than #40 pounds. I don't think the average person realizes how much weight reduction in the crank alone can be achieved. A 4.500" stroke crank for this engine without any weight reduction could weigh #70 pounds. That is 30 pounds and it is right in the front of the car and it will help with power slightly as well. There is a lot of "bad" weight in a crankshaft just riding around doing nothing. But I think the Callies 4.25" Crank stantard weight version costs around 1800 and my Crank is going to end up around 3500(balanced).
An aluminum Block probably would have saved me money in the long run. Or who knows I may have still gone for the Bryant Crank. But it would not have been as likely. Once we decided to do a billet the sky is the limit on stroke so we maxed it out. The cost is pretty much the same not matter what the stroke.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Ron Silva] #449160
08/29/09 06:37 PM
08/29/09 06:37 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Very cool build and a beautiful car as well.
What is journal overlap when talking crankshaft?
68 Barracuda Formula S 340
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Bad340fish] #449161
08/29/09 09:06 PM
08/29/09 09:06 PM
USA
USA
Here you go:
http://victorylibrary.com/mopar/journal-c.htm
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: 65signet] #449162
08/29/09 10:22 PM
08/29/09 10:22 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i feel cubicly challenged
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: sixpackgut] #449163
08/31/09 10:38 PM
08/31/09 10:38 PM
Castle Rock, CO
W
wegner426 Offline
wegner426  Offline
W
Castle Rock, CO
Car looks great Ron!
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Dragula] #449164
09/01/09 09:08 PM
09/01/09 09:08 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
How much does that valiant weigh and what are you doing for a radiator and fan.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: 65signet] #449165
09/01/09 11:59 PM
09/01/09 11:59 PM
USA
USA
The Valiant weighs 2900 pounds without me in it and with the 406 iron headed crate motor. This new 501 engine should take at least 50 more pounds out of the car and from the front.
The radiator I have is from Ron Davis and is basically a standard radiator out of his catalog. But I ordered it with a STRAIGHT botom outlet. I am using a 20" engine driven HP flex fan from Permacool. They pull a lot of air. The shroud is off a ford Fairmont or Granada.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Ron Silva] #449166
09/02/09 12:00 AM
09/02/09 12:00 AM
USA
USA
onemore
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: Ron Silva] #449167
09/02/09 04:22 PM
09/02/09 04:22 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Will you go to an electric fan with the new motor?
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: 65signet] #449168
09/02/09 04:32 PM
09/02/09 04:32 PM
USA
USA
No. Nothing in my cooling system will change except I will be running a Edelbrock water pump. I know there is better stuff out now, but I have never been able to make an electric fan cool in the summer heat. I like to go to Del Taco in the summer and go through the drive through. Or, god forbid, I go some some rounds in a race in the summer time.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.......... [Re: RyanJ] #449169
09/02/09 04:37 PM
09/02/09 04:37 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Good points...
I know of a guy who went from roughly 400 inch smallblock to 450 inch smallblock, and because of the heads(230 indy)he has seem very little gain in performance, the car is just harder to hook because of the 4.25 inch crank instead of the 3.79 and 4 inch stuff he used to run.
The 500 inch smallblock is a cool deal, and as a "one off" piece its mighty intriging.
From a practical standpoint there are bunches of ways to get a smallblock to go 10 flat easily on pump gas with way less inches and cost, but Ron has the "cool factor" pretty much sewn up
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
