Page 1 of 29 1 2 3 28 29
SILVALIANT 501 CI Small Block Under way.............. #449110
08/25/09 03:23 PM
08/25/09 03:23 PM
USA
Ron Silva Offline OP
USA
Well, a lot of Guys are asking about this so I thought I would show the specs of my Engine build. My last engine was kind of extreme and I did all the research networking and design by myself, so it was such a pleasure to do this one with RYAN J. He knows so much right off the top of his head it is amazing and we do think alike in many respects. I told him my objectives and he is helping me get there and he is NOT trying to manipulate or change that in any way. A huge asset in my opinion. RYAN is supplying the machine work and most of the parts and is setting up the heads and porting the intake etc. He is also going to do some mock-up to verify a few things and then ship me all the parts in a crate. One thing that planted the seeds for this engine was when I talked to Russ from Indy at MATS. I found out they had a 48 deg option for the 360-1 heads and that I could run a hydraulic roller. I will do all the final assymbly paint etc....
My objectives with this motor are :
Have fun building it.
Have something different and unique but simple.
Run 10.00 in Silvaliant in the summer heat.
Dead reliable valvetrain / low maintinance.
Reasonable driveability for the street.
Mopar R3 48 deg tall deck siamese block.
Bore 4.21, MAX CNC lightened by Ryan
Bryant max lightened 4.500 stroke crank. 340 mains chevy 2.00 pins.
R&R 4340 billet A-Beam connecting rods 6.300 X 2" X .866 small end. Super high end 3/8 bolts.
Indy 360-1 245RP CNC heads w/48deg option and finish ported VV job and assy by Ryan. 1.60 X 2.15 vvs. 360-3 Intake manfold ported by Ryan. T&D Rockers 1.70 ratio.
Custom CP Pistons Mirror dish 11:1 comp, X-Style strutted skirt design forging, lateral gas ports, max lighten pkg.
Custom Bullet Hydraulic Roller steel billet 48 deg cam.
Intake: 264 @ .050", 180 @ .200", .385" lobe, .654" lift with 1.70 Rocker
Exhaust: 268 @ .050", 179 @ .200", .365" lobe, .620" lift with 1.70 Rocker
109 LSA installed @ 105.
I have no idea on HP. But the car has run 11.08 with the 406 crate that is rated at 435 HP. So I am thinking I will make my goal. This car is 200 pounds lighter than my Demon was too, so I will not need as much power. Believe it or not that cam spec above is bigger than the solid roller I had in the demon.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449111
08/25/09 03:31 PM
08/25/09 03:31 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Woah!
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449112
08/25/09 04:25 PM
08/25/09 04:25 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Awesome project!
I wonder how long till it gets a bit more cam *cough, cough* ?
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449113
08/25/09 04:37 PM
08/25/09 04:37 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Ron, wouldnt going to a bigger main diameter give you a little more overlap with the crank? NOt sure if thats a possibility, not sure if the r3's caps would allow much more to make it worthwhile. Betcha it's alot faster than 10.00 .. btw, how are those r3's from indy? Need alot of correcting or no?
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Hot 340] #449114
08/25/09 04:53 PM
08/25/09 04:53 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
I think the journal overlap was a variable that was thought about, so they simply let Sonny Bryant Crankshafts make the call. Sounds like they felt it was a non-issue for this application.
I thought they were going to go 1.88 Rod journal, but maybe that was pushing it abit too far.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Hot 340] #449115
08/25/09 04:57 PM
08/25/09 04:57 PM
USA
USA
I don't think crank strength will be a problem. I offered to pay extra for a 300M billet and also to leave the center counterweights on. Bryant declined to do either. Said it will not be an issue for this engine.
Are you talking about the 48Deg option? They leave about 1/2" more material/metal on the Intake side of the head and then it is like a W-Seires 48 deg Mopar head at that point. As a side note: This actually corrects problems with the intake manifold fitting/port alignment with the RP version of the 360-1 heads.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449116
08/25/09 05:00 PM
08/25/09 05:00 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Cool sounding project, Ron
You might want to consider a stop at the tractor pulls before you head out to the dragstrip with that
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449117
08/25/09 05:03 PM
08/25/09 05:03 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I was talking about the r3 blocks that were coming from Indy..it's my understanding that they were machining them there now..
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449118
08/25/09 05:06 PM
08/25/09 05:06 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I think you'll go faster than 10.00...
Nautilus Racing-
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Hot 340] #449119
08/25/09 05:14 PM
08/25/09 05:14 PM
USA
USA
You would have to ask Ryan. I know he is going to line hone the mains regardless to get the main clearance right and paralell deck it to bluprint the deck height (allowed us to order all the parts without having the block) and surface finish, and he is going to take about 40-45 pounds out of it with the CNC. Plus bore and deckplate hone to 4.21.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449120
08/25/09 05:28 PM
08/25/09 05:28 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
So at 501 has anyone built one this big besides your 474.
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449121
08/25/09 05:31 PM
08/25/09 05:31 PM
Renton Washington
Triple Threat Offline
Renton Washington
Killer, A 500 + inch small block mopar street car that will run hard. You sir are my hero.
Please keep the updates coming as the build progresses.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Triple Threat] #449122
08/25/09 05:35 PM
08/25/09 05:35 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Do you still have the Demon??
I love the valiants and yours is killer looking
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: FASTFISH420] #449123
08/25/09 06:00 PM
08/25/09 06:00 PM
Toronto
mshred Offline
mshred  Offline
Toronto
That sounds like one KILLER setup man! i think you'll be in the 10's easy with that light valiant, maybe even faster! Have fun with it!
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Ron Silva] #449124
08/25/09 06:03 PM
08/25/09 06:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good luck w/that Ron and like everything else you put together, it will haul a$$ and look great doing it!
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Thumperdart] #449125
08/25/09 06:05 PM
08/25/09 06:05 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
That, is the understatement of the year.
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: G_bob] #449126
08/25/09 06:18 PM
08/25/09 06:18 PM
gregsdart Online content
gregsdart  Online Content
Good luck with this project. Sounds like it will be a real stump puller! How good do those heads flow? Looking for 650 or more HP?
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: 68Fastback] #449127
08/25/09 07:24 PM
08/25/09 07:24 PM
USA
USA
Ryan said it is the biggest he has heard of. But a while back a Guy posted on here that he had 4.500 or something like 4.540 stroke and everybody kind of blew him off. I believed him soley based on my experiend with my 474.
Right now with this engine we are at the limits as to what is possibe considering things like rod length to get the piston to clear the counterweights at BDC, and piston length to keep the piston from hitting counterweights AND from coming out of the bore at BDC. He even went with a smaller wrist pin so we could have 3 rings on the piston and keep the wrist pin from going THROUGH the oil ring groove and still have a rod this long.
SRT DEMON ONE SEAT
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: B3422W5] #449128
08/25/09 07:31 PM
08/25/09 07:31 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I wanna see the rods, and crank, Ill bet they are PIRTY!!!
Re: SILVALIANT 501 CI Small Block Under way.............. [Re: Moparnut426] #449129
08/25/09 07:37 PM
08/25/09 07:37 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Thats sound awesome keep us updated, love those small blocks
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
