Re: SILVALIANT 501 CI Small Block Under way..........
[Re: Dragula]
#449150
08/27/09 11:32 PM
08/27/09 11:32 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Are you going to have it dynoed before installing it?
[Re: Comp Chassis 2]
#449152
08/28/09 02:28 AM
08/28/09 02:28 AM
Posts: 6,137 Melbourne , Australia
LA360
Mountain Motors usually have rod ratio's in the 1.4 range, lower in some cases. Sounds like an interesting project Ron, I hope you have fun with it AL....
Alan Jones
[Re: Dragula]
#449157
08/28/09 09:55 PM
08/28/09 09:55 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Soooo, 500 cube small block Mopar is possible, and yet, I have never heard of anyone building one! Had I known this years ago, the engine in my Cuda would probably be different. Visions of P5 Hemi heads and 500 cubes come to mind....
My only question after seeing this post is why has nobody ever built one before now? Why is this all of a sudden common knowledge, yet I have never heard or seen anything even close to that in a sbm before now.
My answer is: just how much is this 500" sbm going to cost???? That might be why nobody has done it yet? Compare that to a 500" BBM and you can quickly see why. I have to say though, it should be one very neat and original build that's for sure. I'm excited to see what happens...too bad you won't stick it on our dyno Ron, that would be neat to get Dulcich down for a day of pics and a nice Mag spread. I'm going for a completely different approach with my new engine...it's a 360" W2 headed R1 block deal with 48° lifter bores. I too hope to go 10.00's but I'll be using race gas. Just thought it would be neat to do 10 oh's in a street-like car and no stroker so I know what it's like to go against the grain Plus I just don't have that much $$$ to spend on an engine build LOL!!
Keep us updated, we're going to want lots of pics
Brian Hafliger
[Re: Dragula]
#449158
08/28/09 09:56 PM
08/28/09 09:56 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Ron's old motor was 474 inches..... INDY sells a 471" Kit now off shelf....
All it takes is a big crankshaft. Most guys doing SB Mopars are not willing to spend the $ to be honest.
However, a 4.5" crank in a SB package will not really be a great "race motor" combo (it's too much stroke IMO) That's really why no one has done one.... It's unusual to spend this kind of $ on a motor that will not be a max effort deal.
The 4.25" crank would be as big as I'd go for a race motor that needs to turn RPM & make big power.
The journal overlap on this 4.5" will be scary with 2.0" rods.
[Re: Ron Silva]
#449160
08/29/09 06:37 PM
08/29/09 06:37 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Very cool build and a beautiful car as well.
What is journal overlap when talking crankshaft?
68 Barracuda Formula S 340
[Re: Dragula]
#449164
09/01/09 09:08 PM
09/01/09 09:08 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
How much does that valiant weigh and what are you doing for a radiator and fan.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#449165
09/01/09 11:59 PM
09/01/09 11:59 PM
Posts: 1,880 USA
Ron Silva
USA
The Valiant weighs 2900 pounds without me in it and with the 406 iron headed crate motor. This new 501 engine should take at least 50 more pounds out of the car and from the front.
The radiator I have is from Ron Davis and is basically a standard radiator out of his catalog. But I ordered it with a STRAIGHT botom outlet. I am using a 20" engine driven HP flex fan from Permacool. They pull a lot of air. The shroud is off a ford Fairmont or Granada.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#449167
09/02/09 04:22 PM
09/02/09 04:22 PM
65signet
El Dorado Ca
Will you go to an electric fan with the new motor?
[Re: RyanJ]
#449169
09/02/09 04:37 PM
09/02/09 04:37 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Good points...
I know of a guy who went from roughly 400 inch smallblock to 450 inch smallblock, and because of the heads(230 indy)he has seem very little gain in performance, the car is just harder to hook because of the 4.25 inch crank instead of the 3.79 and 4 inch stuff he used to run.
The 500 inch smallblock is a cool deal, and as a "one off" piece its mighty intriging. From a practical standpoint there are bunches of ways to get a smallblock to go 10 flat easily on pump gas with way less inches and cost, but Ron has the "cool factor" pretty much sewn up
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
