Summit universal radiators?? #448913
08/25/09 10:47 AM
08/25/09 10:47 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
My Challenger was a 2bbl 318 car and I guess had a small rad support opening. At some point, sombody cut it to fit a 26" radiator in there and did a poor job so I was thinking of ditching the stock type 26" radiator for a cheap aluminum unit.
Anybody install a universal radator in a mopar?? I guess I need a Chevy style with the drivers side upper and pass lower hose locations and would have to mount it using the top and bottom brackets so the cut rad support wont matter.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Summit universal radiators?? [Re: CJK440] #448914
08/25/09 10:58 AM
08/25/09 10:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I got this 26" on e-bay shipped for under $200. It has the brackets on it as well as trans line hook-ups. It bolted right to the core support and the shroud fit right on.
Coming soon!!!!
Re: Summit universal radiators?? [Re: Mr.Yuck] #448915
08/25/09 11:53 AM
08/25/09 11:53 AM
Az
Crizila Offline
Crizila  Offline
Az
The first question you need to ask yourself ( prior to fit issues ) - is it going to be enough radiator to cool my motor.
Fastest 300
Re: Summit universal radiators?? [Re: Crizila] #448916
08/25/09 02:54 PM
08/25/09 02:54 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Sure, but I was thinking a 26" 2 core alum radiator should be comperable to a 3 core 26" brass & copper.
Under $200 shipped is not bad but since the previous owner(s) cut my rad support I don't know how well it will bolt up.
Re: Summit universal radiators?? [Re: CJK440] #448917
08/25/09 03:11 PM
08/25/09 03:11 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Never mind. I found the ones on ebay. Made by Champion?
Even if the rad support was cut too big it still would be easier to get a regular mount radiator to fit as opposed to a universal cross flow.
Any cooling issues with yours?
Re: Summit universal radiators?? [Re: CJK440] #448918
08/25/09 03:19 PM
08/25/09 03:19 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm not an expert on radiator sizing, but if your 360 is making over 400HP that radiaror will be very marginal - IMO.
Fastest 300
Re: Summit universal radiators?? [Re: Crizila] #448919
08/25/09 04:42 PM
08/25/09 04:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my 440-6 makes 400+ haven't seen an issue yet. Temp gauge stays around 170, might float to 200 right after I shut it off, but drops quick as asoon as you re-fire it.
Coming soon!!!!
Re: Summit universal radiators?? [Re: Mr.Yuck] #448920
08/25/09 05:02 PM
08/25/09 05:02 PM
Az
Crizila Offline
Crizila  Offline
Az
From youyr pic I don't think we are talking about the same radiators. Thought the universal Summit rad was a cross flow. Yours looks like a down flow with a bigger tank than the cross flow?
Fastest 300
Re: Summit universal radiators?? [Re: CJK440] #448921
08/25/09 05:14 PM
08/25/09 05:14 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
I’ m using the same Champion radiator in my 69 Super Bee with no cooling issues. My engine is 511 CU, 550 hp . It runs 190 degrees on a 95 degree day with a 180 degree thermostat. It should be plenty for your application.
Re: Summit universal radiators?? [Re: Dabee] #448922
08/25/09 05:31 PM
08/25/09 05:31 PM
Rancho Cucamonga,Ca
3
392charger Offline
392charger  Offline
Rancho Cucamonga,Ca
dabeast2. I noticed you are runnung power brakes. What cam do you have and how do the brakes perform? Any 1/4 mile numbers with that car?
Re: Summit universal radiators?? [Re: 392charger] #448923
08/25/09 07:59 PM
08/25/09 07:59 PM
IA
landon1 Offline
landon1  Offline
IA
idk about the summit rads, but i have a chevy-style griffin 19X26 2 row aluminum rad, which cools my 440 just fine. only problem is having to make a custom lower hose (idk how it would be on a small block.
'71 Satellite Sebring 440
Re: Summit universal radiators?? [Re: 392charger] #448924
08/25/09 08:04 PM
08/25/09 08:04 PM
Dandridge TN
Dandridge TN
The car has never been on the strip. The engine has only been in the car since June. Cam is real mild for the street. The cam card is attached.
Re: Summit universal radiators?? [Re: Crizila] #448925
08/26/09 08:30 AM
08/26/09 08:30 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"From youyr pic I don't think we are talking about the same radiators. Thought the universal Summit rad was a cross flow. Yours looks like a down flow with a bigger tank than the cross flow?"
yes mine is down or "normal" flow. I was just saying mine is cheap and it works if he's looking for something on the cheap side.
Coming soon!!!!
Re: Summit universal radiators?? [Re: Mr.Yuck] #448926
08/26/09 09:37 AM
08/26/09 09:37 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I found the downflows and they are only a little bit more than the universal for a direct fit. I still might have to fool with the mounting since my rad support was butchered but I'm sure the downflow would be a much easier install.
Re: Summit universal radiators?? [Re: CJK440] #448927
08/26/09 09:47 AM
08/26/09 09:47 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how bad was it cut? the one I have had the mounting tabs. I guess you could re-drill them to make a custom fit. It doesn't take much to mount a radiator.
Coming soon!!!!
Re: Summit universal radiators?? [Re: Mr.Yuck] #448928
08/26/09 11:24 AM
08/26/09 11:24 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i use the summit radiator in both my race cars,800 hp and they never see over 180 on a hot Fl day going rounds.
Re: Summit universal radiators?? [Re: bonefish] #448929
08/26/09 03:21 PM
08/26/09 03:21 PM
Az
Crizila Offline
Crizila  Offline
Az
Congratulations! Is that 800HP each or altogether?
Fastest 300
Re: Summit universal radiators?? [Re: Crizila] #448930
08/26/09 07:53 PM
08/26/09 07:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Re: Summit universal radiators?? [Re: Mr.Yuck] #448931
08/26/09 08:34 PM
08/26/09 08:34 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sorry i didnt specify. i forgot i was in the grocery getter section.
Re: Summit universal radiators?? [Re: bonefish] #448932
08/26/09 09:20 PM
08/26/09 09:20 PM
Dandridge TN
Dandridge TN
