Summit universal radiators??
#448913
08/25/09 10:47 AM
08/25/09 10:47 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
My Challenger was a 2bbl 318 car and I guess had a small rad support opening. At some point, sombody cut it to fit a 26" radiator in there and did a poor job so I was thinking of ditching the stock type 26" radiator for a cheap aluminum unit.
Anybody install a universal radator in a mopar?? I guess I need a Chevy style with the drivers side upper and pass lower hose locations and would have to mount it using the top and bottom brackets so the cut rad support wont matter.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Summit universal radiators??
[Re: Mr.Yuck]
#448915
08/25/09 11:53 AM
08/25/09 11:53 AM
Posts: 7,506 Az
Crizila
Az
The first question you need to ask yourself ( prior to fit issues ) - is it going to be enough radiator to cool my motor.
Fastest 300
[Re: CJK440]
#448917
08/25/09 03:11 PM
08/25/09 03:11 PM
CJK440
Ansonia, CT
Never mind. I found the ones on ebay. Made by Champion?
Even if the rad support was cut too big it still would be easier to get a regular mount radiator to fit as opposed to a universal cross flow.
Any cooling issues with yours?
[Re: Crizila]
#448919
08/25/09 04:42 PM
08/25/09 04:42 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Sure, but I was thinking a 26" 2 core alum radiator should be comperable to a 3 core 26" brass & copper.
Under $200 shipped is not bad but since the previous owner(s) cut my rad support I don't know how well it will bolt up.
I'm not an expert on radiator sizing, but if your 360 is making over 400HP that radiaror will be very marginal - IMO.
my 440-6 makes 400+ haven't seen an issue yet. Temp gauge stays around 170, might float to 200 right after I shut it off, but drops quick as asoon as you re-fire it.
[Re: 392charger]
#448923
08/25/09 07:59 PM
08/25/09 07:59 PM
Posts: 565 IA
landon1
IA
idk about the summit rads, but i have a chevy-style griffin 19X26 2 row aluminum rad, which cools my 440 just fine. only problem is having to make a custom lower hose (idk how it would be on a small block.
'71 Satellite Sebring 440
[Re: CJK440]
#448927
08/26/09 09:47 AM
08/26/09 09:47 AM
Mr.Yuck
Brookeville, Md
yes mine is down or "normal" flow. I was just saying mine is cheap and it works if he's looking for something on the cheap side.
I found the downflows and they are only a little bit more than the universal for a direct fit. I still might have to fool with the mounting since my rad support was butchered but I'm sure the downflow would be a much easier install.
how bad was it cut? the one I have had the mounting tabs. I guess you could re-drill them to make a custom fit. It doesn't take much to mount a radiator.
[Re: Crizila]
#448930
08/26/09 07:53 PM
08/26/09 07:53 PM
Mr.Yuck
Brookeville, Md
i use the summit radiator in both my race cars,800 hp and they never see over 180 on a hot Fl day going rounds.
Congratulations! Is that 800HP each or altogether?
