Thanks, I have been browsing Summit this evening. They have Painless Performance #30111 listed for hefty $35, on at 185, off at 170, 3/8 NPT thread. Unfortunately a bit too low for my 180 thermostat (the fan would never shut off as soon as the temp hit 185 since the t-stat would prevent it from ever going down to 170 with the engine running)...
But a bit of research on Painless' website shows their #30110 (which Summit also sells for $37.88 although it does not come up on Summit's search engine for some reason) is perfect - 200 on, 185 off.
I was hoping to find the same switch for a more reasonable $10 or so at a chain store rather than marked up to $40 by the aftermarket companies... but as you know their systems are only set up to search by year/make/model
and I got cross-eyed leafing through the Borg-Warner and other catalogs without success, as I posted earlier.
Now I'm thinking of just ponying up for a Hayden 3651 ($46 at Summit) which uses a thread-in temp sensor, fully adjustable from 160-210, comes with a wiring harness and a relay too!
-Charles
