Re: FUEL PRESSURE FLUCTUATIONS
[Re: QUIKFISH1850]
#447885
08/26/09 07:49 PM
08/26/09 07:49 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I will guess you have a liquid filled gage - -either replace it with non-filled or drain the liquid out.
[Re: rowin4]
#447887
08/26/09 08:22 PM
08/26/09 08:22 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Mine seems to fluctuate as well,,,nothing to do with the gauge either,,,, Could a bad ground,,,or some electrical gremelin do this ? Air in the line do this ?
[Re: 69CHARGERMD]
#447888
08/26/09 08:30 PM
08/26/09 08:30 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I know this sounds crazy but I was having the same issue. The solution was new needle and seats, after trying everything else.
[Re: 69CHARGERMD]
#447891
08/26/09 08:57 PM
08/26/09 08:57 PM
Al_Alguire
Las Vegas
No they looked fine. It was a problem I had very intermittently. I changed them after I had another carb that belonged to someone else on the car. He had an issue we fixed and fired it up on mine just to make sure. Rock solid fuel pressure and it had all new stuff in it. I replacd mine and it returned to rock solid pressure.
[Re: Al_Alguire]
#447892
08/26/09 09:10 PM
08/26/09 09:10 PM
Posts: 316 Ohio
Lil Wedge
Ohio
[Re: Lil Wedge]
#447893
08/26/09 09:15 PM
08/26/09 09:15 PM
markz528
Morrow, OH
Also need to remember that a dead-head regulator needs to be adjusted while the car is running or the settings will not be accurate/repeatable.
[Re: markz528]
#447894
08/27/09 01:52 AM
08/27/09 01:52 AM
your blowing through the needle and seats. you need to get a product engineering return system to keep the fuel flowing. it seems to be a problem with the magnafuel & product engineering high flow pumps.
[Re: Otherlane]
#447896
08/27/09 07:55 AM
08/27/09 07:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What is a dead hard regulator? I've been having problems with my carb.its either shoot gas out the front,rear or both vent tubes out the carb and this happens even though its sits at 7 pounds but not all the time. I have a new BG regulator.do I need to run the engine with the regulator to get a good reading? or trash in the needle and seat. this carb is new.we didn't have this problem when this carb was on the dyno [/quote
A dead head regulator is the NON return type... if its blowing out the vents the pressure is blowing the needle off the set.... I'm sure you havent checked the gauge for accuracy but more than likely its greater than 7 psi... on a known good gauge the needle can handle about 7 1/2 psi, at 8 psi it can blow the needle open(this is why we set the pressure at 7 1/2 max on the production pumps at Chrysler..... I had to flow a TON of pumps in the fuel lab) Or your setting the float level too high... but if you watch the float window(Holley) you might see it creeping upward or dumping fuel out while open... which is a pressure issue OR bad needle and seat
[Re: Otherlane]
#447898
08/27/09 08:35 AM
08/27/09 08:35 AM
MR_P_BODY
I have a two port bg regulator but while the car running the needle at 7 and it shoots the gas out.the gas is right at the site level but I don't know where it is while its running.i will check it out when I get home.thanks p-body
Forget the gauge right now.... lower the pressure on the regulator(way low) and get the engine running then slowly up the pressure on the regulator till you get a idea where it will hold at.... then do a gal per minute flow test(in a bucket)
