nitrous plug recommendation? #447557
08/23/09 09:58 PM
08/23/09 09:58 PM
South Dakota
dakotahotrodder Offline OP
South Dakota
What spark plugs do you guys use for a nitrous application on a 440 with edelbrock heads spraying around 150? I run Autolite 3923 in it normally. Thanks for the help.
Re: nitrous plug recommendation? [Re: dakotahotrodder] #447558
08/23/09 10:02 PM
08/23/09 10:02 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
You can go with 3932 or NGK 10s.The 10s are easy to read.I like 3932 but can be a pain to get a read on.
Re: nitrous plug recommendation? [Re: 8secDart] #447559
08/23/09 10:06 PM
08/23/09 10:06 PM
South Dakota
South Dakota
Ok thank you. What would you recommend the gap at ...035?
Re: nitrous plug recommendation? [Re: dakotahotrodder] #447560
08/23/09 10:14 PM
08/23/09 10:14 PM
Colorado
506RR Offline
506RR  Offline
Colorado
For that combo I would use an NGK 9. A 10 will work, but is a little overkill for that combo. I say .030 for the gap on the plugs.
I run NGK 9's with a .030 gap on my 505 motor with ~165 HP shot, and they work great.
Re: nitrous plug recommendation? [Re: 506RR] #447561
08/23/09 10:28 PM
08/23/09 10:28 PM
8secDart Offline
8secDart  Offline
I agree the 9s are best,but if he's new to nos the 10s are safe.Plug gap 30 to 35 will work.
Re: nitrous plug recommendation? [Re: 8secDart] #447562
08/23/09 10:34 PM
08/23/09 10:34 PM
South Dakota
South Dakota
What is the actual part # of the NGK 9 or 10? I've never used that brand before. I used to use the kit a few years ago with a stock headed motor, but have only sprayed this motor a couple times when I first built it 4 years ago. On that day I ran a 11.33 n/a and with a 100 shot went 10.60. I didn't change plugs for that amount, just backed the timing down 5 degrees. Thanks for the help.
Re: nitrous plug recommendation? [Re: dakotahotrodder] #447563
08/23/09 11:05 PM
08/23/09 11:05 PM
Colorado
506RR Offline
506RR  Offline
Colorado
Here is the info for the "9" plugs:
R5671A-9
Stock No. 5238
Re: nitrous plug recommendation? [Re: 506RR] #447564
08/24/09 12:11 AM
08/24/09 12:11 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
R5671A-9
Stock No. 5238
is that a projected tip or non projected tip plug?
Re: nitrous plug recommendation? [Re: Quicksilver440] #447565
08/24/09 12:42 AM
08/24/09 12:42 AM
peoria, az
B1satellite Offline
B1satellite  Offline
peoria, az
Most important what fuel and how much compression?
Re: nitrous plug recommendation? [Re: Quicksilver440] #447566
08/24/09 01:41 AM
08/24/09 01:41 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
R5671A-9
Stock No. 5238
I believe the 71 's are non and the 72's are projected.
Re: nitrous plug recommendation? [Re: RemCharger] #447567
08/24/09 06:34 AM
08/24/09 06:34 AM
South Dakota
South Dakota
Thanks for the help everyone. The comp. is 10.7:1 and I will use Turbo blue 110 gas.
Re: nitrous plug recommendation? [Re: 8secDart] #447568
08/24/09 09:29 AM
08/24/09 09:29 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
If you miss your tuneup, you can take a strap out on a 9 without damaging the pistons for the most part. If you do this with a 10, the piston will be hurt.
0.02
8.30's @3400 lbs
Re: nitrous plug recommendation? [Re: Mike Swann] #447569
08/24/09 03:57 PM
08/24/09 03:57 PM
Central Valley, CA.
Central Valley, CA.
0.02
Mike...why is this? Is it just because your tuneup would have to be off more to lose the strap on a 10..or?
Re: nitrous plug recommendation? [Re: Quicksilver440] #447570
08/24/09 04:12 PM
08/24/09 04:12 PM
UK
602heavy Offline
602heavy  Offline
UK
I ran that exact same combo hitting it with a 250 shot & a -8 NGK plug , As said before , the NGKs are a lot more forgiving if you loose a ground strap , i think a -10 will be overkill & confuse the tunning process.
Re: nitrous plug recommendation? [Re: Quicksilver440] #447571
08/24/09 09:52 PM
08/24/09 09:52 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
0.02
You are trying sneak up on lean and "Goldilocks" timing. Doent matter if its fuel, N20 or Alcohol. This applies in So Cal weather too, cant say about back east.
If you nick a 9 (over) the piston is generally ok.
If you nick a 10, the piston has some damage. This is from personal experience because it is such a cold plug.
If you miss it by a mile, it doesnt matter.
BTW, this is some other mis-information in this thread too. Do not run big plug gaps.
8.30's @3400 lbs
Re: nitrous plug recommendation? [Re: Mike Swann] #447572
08/24/09 10:11 PM
08/24/09 10:11 PM
8secDart Offline
8secDart  Offline
I agree 30 to 35 is wide.On his tune it should be fine.On some of my little motors the wide gap helps keep the plugs a little cleaner when not on the jug.
