Can excessssive lash pound a pushrod over time and cause it to bend ??
Engine ran great, VERY slight miss. The valves were noisy so I pulled the valve cover to check lash and verify oiling and found the bad pushrod.
Lash was excessive but not enough to where the cup came out of the adjuster. Valve and lifter are operating and no obvious sign of a bent valve.
Car sat a LONG time, maybe a sticky guide when it was first started?
Can't get the pushrod out so the intake has to come off anyway, it's just the possible cause that's bugging me. It is amazing that it ran so well!
Leakdown good, TDC is correct, motor is all stock 50K miles.
![](/ubbthreads/images/graemlins/thumbs.gif)
