Alu rod question #447183
08/23/09 03:37 PM
08/23/09 03:37 PM
nc
E
emarine01 Offline OP
E
nc
How are you guys doing static compression math with alu rods , are using total clearance numbers or do you add rod stretch or elongation from heat or what? The extra .020 clearance is a 1/2 compression point on my engine
Re: Alu rod question [Re: emarine01] #447184
08/23/09 04:16 PM
08/23/09 04:16 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would like to hear too as I'm doing mine with no stretch in math?
Re: Alu rod question [Re: Dodgem] #447185
08/23/09 04:36 PM
08/23/09 04:36 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Umm....technically...the rod doesn't stretch when it's "Static"!!!
I never worried about all that "stretch" or growth" stuff with my BME aluminum rods, until I had it apart after 350 passes and saw shiney spots on my heads, and the pistons...figured .054 clearance was enuff, and it almost was...
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Alu rod question [Re: MoparBilly] #447186
08/23/09 05:22 PM
08/23/09 05:22 PM
Come on Billy, BME says .055 minimum, not .054 Just kidding I think it is real important to write down the deck or dome hieght and check it after running them every 200 or more runs, once they start to stretch it is probally a good time to replace them
Re: Alu rod question [Re: MoparBilly] #447187
08/23/09 07:58 PM
08/23/09 07:58 PM
nc
E
E
nc
Technically it does when its hot, but if the word static is twistin your panties we can change to mechanical compression and back to the point which you kinda answered in a backassward way, I am guessin you were running a .040 head gasket and you had some form of interference @ .054 than .019 was the rod gain ,<.035 min for steel rod> I can add that to my static compression math and come up with a more realistic number, thankx
Re: Alu rod question [Re: emarine01] #447188
08/23/09 08:37 PM
08/23/09 08:37 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
With my GRP rods I run .035" clearance. You shouldn't have stretch during compression stroke. But, you probably do when the valves are open.
Leon
Re: Alu rod question [Re: Leon441] #447189
08/23/09 11:03 PM
08/23/09 11:03 PM
nc
E
E
nc
Wow .035 is tight for a alu rod , you must have a light piston and a short stroke, I run my BMEs @ .058 with a 430 gram piston and a 4 inch stroke
Re: Alu rod question [Re: emarine01] #447190
08/24/09 09:08 AM
08/24/09 09:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe the original question was "should rod stretch be calculated as additional deck height when figuring out the mechanical compression ratio"?
Doug
Re: Alu rod question [Re: dvw] #447191
08/24/09 09:50 AM
08/24/09 09:50 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Ummm...technically Doug,
Rod stretch would be calculated as less deck height...right? My head is starting to hurt.
Re: Alu rod question [Re: MoparBilly] #447192
08/24/09 03:56 PM
08/24/09 03:56 PM
nc
E
E
nc
The BME spec for piston to head is .060 , around .025 more than a steel rod engine, when doin engine math if you use the .060 figure you are shorting the compression ratio quite a bit, So what I was asking was what was a good figure to use for engine math that was closer to actual ratio after heating the rod ,stretch or what ever you wan to call it , since Alu grows, swelles stretches or what ever more than steel if you had a real number you can figure the ratio closer, Take Bills engine , he had piston to head interference at .054 so we now know in a running engine with a alu rod the .054 clearance is no longer there , thats why you got the shiny spots so if most engine math is done using .035 or .040 piston to head math a Alu rod engine should figure a lower than .060 number, now my head hurts also
Re: Alu rod question [Re: emarine01] #447193
08/24/09 04:04 PM
08/24/09 04:04 PM
for te sake of figuring your actual static compression ratio,(on a warm engine) just use .015 shorter deck height in your equation.
Re: Alu rod question #447194
08/24/09 04:27 PM
08/24/09 04:27 PM
nc
E
E
nc
Thanks Dram, I was hoping some of the guys with more experience would kick in ,I cant be the only crazy one thinkin of crap like this .015 is a good number I was going to be greedy and use .019 but .015 is good
Re: Alu rod question [Re: MoparBilly] #447195
08/24/09 08:46 PM
08/24/09 08:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree. I was thinking the height of the piston would be calculated at a taller figure to compensate for the rod being longer when warm. I used the term deck hieght incorectly.
Doug
Re: Alu rod question [Re: dvw] #447196
08/24/09 08:54 PM
08/24/09 08:54 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
Aluminum rods grow during shut down when in gear. That is not stretch. That is why many racers shut down in neutral and avoid piston to head or valve contact.
Re: Alu rod question [Re: ValiantRich] #447197
08/24/09 09:10 PM
08/24/09 09:10 PM
nc
E
E
nc
Grow is a good word too They also grow a lot at high revs pulling down form tdc on the intake stroke
