68 Barracuda 340 4 spd Formula S....IS IT??????????? #446759
08/23/09 08:04 AM
08/23/09 08:04 AM
Newfoundland
mopar_man Offline OP
Newfoundland
68 barracuda going up on auction here. As stated above it says its a Formula S , has a 340 4 spd with console.
GREEN guts and somekind of dark/navy blue outside.
doubt if there's a build sheet
So the question is , what or where do I look to confirm
that this car is really an "S"?
what should Vin be ? etc. etc
Re: 68 Barracuda 340 4 spd Formula S....IS IT??????????? [Re: mopar_man] #446760
08/23/09 08:52 AM
08/23/09 08:52 AM
Newfoundland
Newfoundland
bump for the morning crew . Plus thinking about bidding on it .
Re: 68 Barracuda 340 4 spd Formula S....IS IT??????????? [Re: mopar_man] #446761
08/23/09 09:17 AM
08/23/09 09:17 AM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
Quickest way to check is the VIN. In 68 The only way to get the 340 was a formula S option. So having stated that if you look at the 5th diget of the VIN it will be a P. If its any other digit its not a 340 car. So the vin should be something like BS29P82xxxxxx Good luck.
1979 Chrysler 300 1968 Barracuda project
Re: 68 Barracuda 340 4 spd Formula S....IS IT??????????? [Re: LS-300] #446762
08/23/09 10:53 AM
08/23/09 10:53 AM
Newfoundland
Newfoundland
Thanks for the info
Re: 68 Barracuda 340 4 spd Formula S....IS IT??????????? [Re: mopar_man] #446763
08/23/09 11:49 AM
08/23/09 11:49 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Also, if it has a fender tag, on the second row from the top, there will be a 7 under the "F".
