O-ring pump seal 727 how to install #446696
08/23/09 02:11 AM
08/23/09 02:11 AM
Red Bluff, CA
W
WilliamHall Offline OP
super gas
super gas
W
Red Bluff, CA
The cross-sectional area of the O-ring seal is rectangular. When installed does the longer side of the rectangle stick out or does it rest inside the grove? I can see how the seal could be installed both ways.
Re: O-ring pump seal 727 how to install [Re: WilliamHall] #446697
08/23/09 02:16 AM
08/23/09 02:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Long side out lube with petroleum jelly
Re: O-ring pump seal 727 how to install [Re: WilliamHall] #446698
08/23/09 10:06 AM
08/23/09 10:06 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
lay it on a flat surface, it's self- explanatory
