Page 1 of 5 1 2 3 4 5
CUT THE BULL ! #446602
08/23/09 01:28 AM
08/23/09 01:28 AM
E
EJ440 Offline OP
EJ440  Offline OP
E
after sending 15000.00 with a well known mopar builder that said my 500 cid crate motor would make 800 hp. its time for me to do it myself . my 3100 lb a body will only 10.20's. i was going 10.40's with a 30 over 440 with stage six heads that ran on pump gas . here what he sent me. it's 4.38 bore 4.15 crank. cam is 706/690-274\274 @50 .440-1 fully ported. heads are 69.9 cc 13.1 comp. converter is a 5500 coan made for motor. 4.88 dana 60 and coilover ladder bars 13-31 good year slicks 1.43 60ft . please dont tell me call no one . tell me your real world combs and et and what would you do?
Re: CUT THE BULL ! [Re: EJ440] #446603
08/23/09 01:41 AM
08/23/09 01:41 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I'd be bummed, that's for sure. I'd get it out and get it on a RELIABLE dyno. Actually before I did that, I'd do a compression and leak down test while still in the car. Did the builder dyno test it? Were the heads on a flow bwnch??
If it does make the numbers the builder claimed, the problem is else where.
I would also think 4.88's are WAY too much gear at that weight. 4.56's, or 4.30's would be more like it...
This ought to be very interesting...
Re: CUT THE BULL ! [Re: cudadoug] #446604
08/23/09 08:24 AM
08/23/09 08:24 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I would tell us who the engine builder was so we know who to look out for when spending our money....
Re: CUT THE BULL ! [Re: cudadoug] #446605
08/23/09 08:31 AM
08/23/09 08:31 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Are you sure the engine is in proper tune? Jetting. timing, valve lash, shift points, etc.? Was the engine dynoed? If not, I wouldn't give up on it just yet.
2 kids and a dog
Re: CUT THE BULL ! [Re: TonyS451] #446606
08/23/09 08:38 AM
08/23/09 08:38 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
what was the MPH?
Mopar Performance
Re: CUT THE BULL ! [Re: moparniac] #446607
08/23/09 08:47 AM
08/23/09 08:47 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
what was the MPH?
MY THOUGHT'S EXACTLY
ET has little to do with HP. Look at your MPH. Look at what it was with old engine. MPH=HP ET=combination
If you didn't pick up MPH you may want to check the tuneup and some of the other items mentioned. Once you have absolute proof go kick the engine guys butt.
Leon
Re: CUT THE BULL ! [Re: EJ440] #446608
08/23/09 09:03 AM
08/23/09 09:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Who assembled the engine... you or the builder
and yes what is the MPH
Re: CUT THE BULL ! [Re: TonyS451] #446609
08/23/09 09:46 AM
08/23/09 09:46 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
I wouldn't give the name of the builder to trash them until you are POSITIVE it is lack of power from the engine... and not an issue with the trans or convertor... or?
Re: CUT THE BULL ! [Re: camdog440] #446610
08/23/09 09:58 AM
08/23/09 09:58 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Way too many variables to bug the builder, check compression, leak down and cam timing , its good to know for a new engine anyway , test and tune to dial it in,
Re: CUT THE BULL ! [Re: emarine01] #446611
08/23/09 10:13 AM
08/23/09 10:13 AM
gregsdart Offline
gregsdart  Offline
Check everything that got changed from your old combo to your new combo. We don't know near enough about the motor to make any judgments what so ever. Same with the converter, or what headers it was dynoed with, then raced with. We need all the details to help. Did the compression go way up? What plug gap you running? Ignition system? Fuel system? Shift rpm? 4.88 and 31 inch tire looks to be too much rpm for 1/4. I calculate almost 8,000 rpm at 140 mph with 7 percent slip in the converter. The motor would be laying down long before 8,000rpm. You should easily be able to pull 140 mph with 800 hp.
Re: CUT THE BULL ! [Re: EJ440] #446612
08/23/09 10:18 AM
08/23/09 10:18 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
If you want to compare go to my web site, car ran best of 10.08 at 132 451ci E heads 620mp cam and a 950hp carb on a victor intake. lots of specks to look at
add below
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: CUT THE BULL ! [Re: MR_P_BODY] #446613
08/23/09 11:06 AM
08/23/09 11:06 AM
E
EJ440 Offline OP
EJ440  Offline OP
E
thanks for te replys guys. yes i have done all of the above.the trans is new, covertor new.timing has been from 32 all the way to 40. carb is a 1050,jeting has been from 88 all the way to 98. was runing slower than that tiil we move the timing chain from retart 4 degree to straight up picked up from 10.50 down to 10.20 mph has been from 126-133. i have tried leveing 4000 to 5500 on the trans brake. the car feels like a dog out of the hole. no dyno on this motor .builder says he builds them all of time and he just dyno one that 807 hp and 701tq that is the same as mine. he said the heads flow 370ish .i will be taking this motor out today .
Re: CUT THE BULL ! [Re: EJ440] #446614
08/23/09 11:12 AM
08/23/09 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What did your leak down show.... if you advanced it
the 4* to straight up, why not try going to 4* advanced
that will pick up the torque..... I wouldnt be pulling
the engine out yet
Re: CUT THE BULL ! [Re: EJ440] #446615
08/23/09 11:16 AM
08/23/09 11:16 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
What trans is in the car?
What is the shift point?
Trap RPM ?
Re: CUT THE BULL ! [Re: EJ440] #446616
08/23/09 11:18 AM
08/23/09 11:18 AM
800 HP,126-133MPH @ 3100 lbs.???!!!!!! NOT GOOD!
Re: CUT THE BULL ! [Re: EJ440] #446617
08/23/09 11:25 AM
08/23/09 11:25 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
With my one recent bad choice of shops to deal with, in reading all this here are a few ?????
Was this a new crate motor to start with or your old crate motor?
What kind of shop would build a 15k motor and not dyno it in house to cover there behind?
Ive learned real shops provide build sheets, dyno sheets, I hope im wrong but I hope when you start looking into the motor its got the parts it should have and what you paid for.
The machine shop im dealing with now seems very top notch and they take time to talk to me, I felt bad thinking about asking them to make up a work order in detail prior to doing anything, but they were one step ahead and had one, they said thats how the business is run.
Please keep posting on what you find....I hope its not from the flordia shop ive delt with, if so break out the pre-lube.
Re: CUT THE BULL ! [Re: quick77rt ] #446618
08/23/09 11:31 AM
08/23/09 11:31 AM
Q
Quicktree Offline
Quicktree  Offline
Q
that pretty much sums it up. if it were mine it would be going on a different dyno soon.
Re: CUT THE BULL ! [Re: MR_P_BODY] #446619
08/23/09 11:37 AM
08/23/09 11:37 AM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
.... I wouldnt be pulling the engine out yet
why not?? not even close to 800 ponies like it supposed to have. sounds like another tail light warranty from a supposed guru.
Re: CUT THE BULL ! [Re: gregsdart] #446620
08/23/09 11:39 AM
08/23/09 11:39 AM
E
EJ440 Offline OP
EJ440  Offline OP
E
no dyno sheet on this motor. it was put together whit his proving combo. header are 2in hooker fender well .msd 7 al2. fuel punp is aeromovive 1000.i shift @6800b traps about 7000 .compression is 13;1 69cc head. old motor was a 30 over 440 stage 6 heads 76cc .cam was isky 660 282@50. 1050 dom . the same 2in headers.
Re: CUT THE BULL ! [Re: weedlayer] #446621
08/23/09 11:41 AM
08/23/09 11:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why would you... you can test more things while its
still in the car... more so than while on a stand
