TQ surges, tranny has no power... #446479
08/22/09 10:14 PM
08/22/09 10:14 PM
SK, Canada
E
etek Offline OP
etek  Offline OP
E
SK, Canada
Hey guys,
Finally got my Challenger (318, Performer intake, Thermoquad carb) running and took it out for a once around the block....when idling in the shop, it would idle OK at ~600rpm, then increase to 1200 for 10-15 secs. Then it would go back to normal idle. Mix screws set at 1.5 turns each....(from the 2.5 initial).
As well, when I put it in gear, it goes forward, but I can't get it to go fast!!! The rpm icreases, but the speed doesn't!! Just kinda idled it around the block, tried a few pumps and pulled it back in to figure it out....
Thanks much!
Re: TQ surges, tranny has no power... [Re: etek] #446480
08/23/09 05:08 AM
08/23/09 05:08 AM
SK, Canada
E
etek Offline OP
etek  Offline OP
E
SK, Canada
Bump...someone gotta have some opinions!
Re: TQ surges, tranny has no power... [Re: etek] #446481
08/23/09 05:46 AM
08/23/09 05:46 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Ummm TQs are junk as you're finding out, and your trans is messed up.... That about sums it up .
Re: TQ surges, tranny has no power... [Re: CokeBottleKid] #446482
08/23/09 10:20 AM
08/23/09 10:20 AM
SK, Canada
E
etek Offline OP
etek  Offline OP
E
SK, Canada
Ahhh, wrong-o Coke-head kid....I've had TQ's that have run better, producing more HP than anything else out there!! Once they are tuned properly, they perform extremely well -but it's not for the tuner kid crowd, so you'd better stick with Holley!
Re: TQ surges, tranny has no power... [Re: etek] #446483
08/23/09 10:45 AM
08/23/09 10:45 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you want people around here to help you you need to curb the attitude. TQs either work real well or not at all. Your's sounds bad. Rebuild it or replace it. Have you bothered to check for vacuum leaks?
Re: TQ surges, tranny has no power... [Re: stumpy] #446484
08/23/09 11:12 AM
08/23/09 11:12 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the post he got wasn't helpfull at all and more disturbing really, so I understand the reaction.
in another note:
I'm agree about some vacuum leak around. Check for that first
Tranny.... could converter get damaged ?
Re: TQ surges, tranny has no power... [Re: stumpy] #446485
08/23/09 11:37 PM
08/23/09 11:37 PM
SK, Canada
E
etek Offline OP
etek  Offline OP
E
SK, Canada
I've been on here for a while and his is the first stupid/crappy reply I've had - yours is the second. If you don't want to help, don't reply.
Thanks to the USEFUL replies - figured out there where a couple sneaky (tube to charcoal can not tight, one base bolt loose) vaccuum leaks and resest the timing - runs like a charm now!!!! TQ's are awesome!!
As for the tranny, was totally due to a fluid lock. Once I got it running the fluid level went way down. Filled it up and now she ROARS!!
Re: TQ surges, tranny has no power... [Re: CokeBottleKid] #446486
08/24/09 08:23 AM
08/24/09 08:23 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Hey Coke,
Wow you were a really big help on this thread! Now insert foot in mouth.
etek,
I'm a TQ fan as I used to run a tweaked 850cfm TQ on my old 340-4spd Duster.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: TQ surges, tranny has no power... [Re: MY340] #446487
08/24/09 08:58 AM
08/24/09 08:58 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Etek you have gotten your last help from me. Enjoy!
Re: TQ surges, tranny has no power... [Re: stumpy] #446488
08/24/09 01:25 PM
08/24/09 01:25 PM
SK, Canada
E
etek Offline OP
etek  Offline OP
E
SK, Canada
When was the last time you helped me??
Re: TQ surges, tranny has no power... [Re: etek] #446489
08/24/09 01:44 PM
08/24/09 01:44 PM
SK, Canada
E
etek Offline OP
etek  Offline OP
E
SK, Canada
I should have tried this:
Engine Start Fluid
