Will my 8-3/4 hold up?
#446034
08/22/09 01:22 PM
08/22/09 01:22 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
will my stock 8-3/4" rear hold up to slicks behind my new motor? It will be a mild street 451 that should be in the 550 horse range once tuned properly. It's a footbrake / 727 car. The rear end has recently been rebuilt with all new bearings and a fresh sure-grip unit. But its an older gearset that makes noise and has stock axles, and it will be pushing a full weight 67 B-body.
Re: Will my 8-3/4 hold up?
[Re: StealthWedge67]
#446038
08/22/09 02:08 PM
08/22/09 02:08 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I feel uniquely qualified to answer this one...
3875# '67 Charger running 4.10's and slicks
I ran my 446" at just under 500hp for quite some time, and the stock axles were twisting up. A set of Dutchmans solved that until I went to a 560HP 496" motor, then the Dutchmans twisted and I upgraded to 35 spline Dutchmans. This has worked OK, but now that I'm hitting it with nitrous, I'm just waiting for it to explode. The weak link is now the caps. The cost of the caps and machine work make it cost ineffective to proceed with this rear any more.
I bought a Dana 60 housing for $125, housing ends and perches for $100, a spool for $180, used gears for $75, bearing kit for $125, $350 for new axles and bearings, and $150 in labor to shorten the housing. Total: $1005.
Compare that to he necessary work on an 8 3/4. Mark Williams cap is $100 and $250 to machine and install it, and it will only buy you a little bit of durability. 35 spline axles are $350, spool to fit the bigger axles is $180. Total: $880
$125 is all you'll save and not have NEAR the durability. I got here incrementally, but I can sell off my parts to recoup some cost. Heck, I'll sell you my whole complete running 35 spline 4.10/spool rear out of my Charger and save you some effort, but you will not want to go any faster than 11.00. I've had it to 10.75, but I really don't trust it down there, thus the Dana.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
#446039
08/23/09 12:27 AM
08/23/09 12:27 AM
Thumperdart
State of confusion
Of course it will........... I`ve been running mid to low 10`s for years and mine`s still tickin and plan on keepin it too.
[Re: moparniac]
#446043
08/23/09 09:21 AM
08/23/09 09:21 AM
Quicktree
just a matter of time. then
The concensus by MOST on the board is its gonna blow.... I think maybe 3 members will tell you its gonna hold up .... not good odds if you ask me
WATCH IT,they will make a movie about you
[Re: moparniac]
#446045
08/23/09 09:31 AM
08/23/09 09:31 AM
Posts: 52,972 Romeo MI
MR_P_BODY
There are certain things I would do to the 8 3/4 to help it live.... bearing caps and a back brace. The stock axles arent any worse than the other stock axles... they will twist(just like any stock axle) My 8 3/4 has been living just fine but now I have the alum center in it and my car is light.... to me weight is what kills the 8 3/4..... my best 60' is 1.19 with a normal 1.21. I was running a complete stock 8 3/4 for years with a back brace and good axles (had over 600 passes and it finally broke the stock caps
[Re: MR_P_BODY]
#446046
08/23/09 10:34 AM
08/23/09 10:34 AM
Quicktree
by the time you do all of that you could have bought a dana (ford truck rear) or a real race rear end
[Re: Thumperdart]
#446049
08/23/09 10:45 AM
08/23/09 10:45 AM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Mine is holding up so far. 3300lb aftermarket axles from DR Diff, Alum center section. No back brace.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: moparniac]
#446051
08/23/09 10:55 AM
08/23/09 10:55 AM
Thumperdart
State of confusion
That should work..........I`m done racing for quite a while since I met my 9-sec goal and actually enjoy driving it more than racing it + it`s WAY cheaper.
[Re: Thumperdart]
#446052
08/23/09 11:27 AM
08/23/09 11:27 AM
Quicktree
Dom have ever had real slicks on your car?
[Re: Quicktree]
#446053
08/23/09 11:47 AM
08/23/09 11:47 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
How often do you plan to race it ?? I can tell you my son and I both have 8-3/4 rears in our cars. His Dart has been on the road since 1997 and it has been raced a few times a year since 2001. My 63 has been raced about 6 times since I put it on the road in 2006. Both rears are all stock but I have a Locker in mine. We had the axles out last year and both his and mine are not twisted. I figured we would run it until the axles twist or something breaks but they are holding up fine in our mid 11 cars we race about 2 or 3 times a year. Thats why I ask how much you will race it as if only a couple times a year I would go with it and see how it holds up. Ron
