Re: meter's question
[Re: Takashi]
#445821
08/22/09 02:12 PM
08/22/09 02:12 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Takashi
you may get a little more help in the question and answer section. To me something lost its connection... of course what it is is the question.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Takashi]
#445822
08/22/09 02:18 PM
08/22/09 02:18 PM
Posts: 21,837 Kirkland, Washington
Pacnorthcuda
about my 64 440wgn's meter. few days ago,temperature,fuel and oil meter haven't work definitely.these meter's hands beyond the upper limit point. so I changed solid state voltage limiter.these hands don't beyond the upper limit point but these don't work at all. I can't understand right reason why don't meters work....
Please give me good advices!!!!
OK, firt all three were pegged (reading HI) right? So you replaced the voltage limiter and not they don't move at all. Did something not get reconnected in the process? Its the limiter grounded?
[Re: Takashi]
#445825
08/22/09 06:59 PM
08/22/09 06:59 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I would check voltage into and out of the voltage limiter first
Allen
[Re: Takashi]
#445827
08/23/09 03:00 AM
08/23/09 03:00 AM
Posts: 7,759 So Cal
HealthServices
So Cal
What I meant was, is it possible to see if the input voltage is where it is suppose to be where it is plugged in and are you getting correct the output voltage.
Allen
[Re: Takashi]
#445829
08/23/09 03:14 AM
08/23/09 03:14 AM
Posts: 7,759 So Cal
HealthServices
So Cal
Sorry I do not know which is which. do not have the schematic to look it up.
#1 should be ground. Don't assume you have it make sure with a meter.
On the other two one should be battery voltage and the other the reduced voltage.
Allen
[Re: Takashi]
#445831
08/23/09 03:44 AM
08/23/09 03:44 AM
Posts: 7,759 So Cal
HealthServices
So Cal
I was afraid of that.
I'm not familiar with your gauge assembly were you able to remove and replace the limiter without removing the gauges?
Don't forget to check that your guages and voltage limiter has a good ground.
Also make sure (sounds stupid) that the fuse is not bad.
Allen
[Re: Takashi]
#445833
08/23/09 03:59 AM
08/23/09 03:59 AM
Posts: 7,759 So Cal
HealthServices
So Cal
The three gauges all went bad at the same time but have a different position after you re-installed the new limiter. Make sure - it was installed correctly,
- the ground was not disturbed,
- a fuse was not blown while trying to replace everything,
- no other wires were disturbed.
- the wires were re installed where they were before.
Allen
