Is a sway bar REALLY THAT important...? #445597
08/22/09 01:33 AM
08/22/09 01:33 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Is a sway bar really that important on a stock,no frills,zero performance oriented car such as a station wagon?
One of the sway bar brackets on the frame of my 72 Fury Wagon has broken the welds.
If I choose to take the sway bar off the front,will I notice any difference in handling? Im not running an Autocross or any other slalom type event. Just normal everday driving in traffic and such.
Is it safe to remove it?
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445598
08/22/09 01:48 AM
08/22/09 01:48 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
it will lean a bit more.
take it off and try it.
Re: Is a sway bar REALLY THAT important...? [Re: 451Mopar] #445599
08/22/09 02:07 AM
08/22/09 02:07 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You will notice. Makes a big difference on my '66 Charger. In modern traffic, keep the sway bar.
Re: Is a sway bar REALLY THAT important...? [Re: bobby66] #445600
08/22/09 02:16 AM
08/22/09 02:16 AM
Nelson-New Zealand
BIG-MIKE-500 ci Offline
Nelson-New Zealand
Fix it so it works; put Nolothane Bushes on the rods on the ends & you will have a far better(safer) handling vehicle.
The factory put it there for a damn good reason. & new bushes will only make it better.
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445601
08/22/09 02:59 AM
08/22/09 02:59 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Yes!
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445602
08/22/09 03:54 AM
08/22/09 03:54 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If the broken sway bar bracket is the end link you will not notice a difference with it off because it is not connected anyways.
Now if you were able to connect it you would notice a difference.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Is a sway bar REALLY THAT important...? [Re: HealthServices] #445603
08/22/09 07:45 AM
08/22/09 07:45 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
What was the car doing when the sway bar broke,were you drivng it like it was a racer?
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445604
08/22/09 08:14 AM
08/22/09 08:14 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Good tires and bigger rims will improve the handling making a swaybar optional in my opinion.
Back in the day I use to run my Dart with a huge addico swaybar and crap tires and 14" rims. Now I have a Duster with no swaybar with 15" x 8" rims with modern performace radials and it handles very well.
As good as the Dart? The Dart was a pretty flat handling car and I give it the slight edge but the Duster I can push pretty damn hard in the corners.
I plan on getting bar for it because I'm spoiled by modern handling cars (I had a Spirit R/T that I'd get one of the rear tires to lift cranking around corners) and like to push.
For the average guy, lack of swaybar not a deal killer if the rubber is good.
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445605
08/22/09 08:26 AM
08/22/09 08:26 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So is it possible the sway bar bracket was actually doing a good job before it broke and the fact that it broke might indicate that it indeed was being decently loaded and therefore working?
I would repair it.
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445606
08/22/09 10:30 AM
08/22/09 10:30 AM
Az
Crizila Offline
Crizila  Offline
Az
Anti-sway bars are an important handling aid on any car and imparticular big iron like a wagon. Fix it!! And while your at it add one to the rear if it doesn't have one. Had a 78 Newyorker with only a front bar. At speed it was scary. Added a 7/8" rear bar and it was like driving another car. What an improvement. I race a big "B" body car ( over 4,000 lbs.) Pulled the front bar off once to try and save a little weight up front ( it also has a rear bar ). It wasn't worth the discomfort at the big end of the track. Put it back on. I also believe the rear bar helps keep the car nice and flat at launch.
Fastest 300
Re: Is a sway bar REALLY THAT important...? [Re: Crizila] #445607
08/22/09 10:40 AM
08/22/09 10:40 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
My 3800lb '70 GTX handled fine without the front one being hooked up for years.
Romping through the traps at 124 mph, plenty of power on tap too.
Ma Mopar churned out millions of cars without bars, not that important to some folks.
Re: Is a sway bar REALLY THAT important...? [Re: gdonovan] #445608
08/22/09 11:43 AM
08/22/09 11:43 AM
"handled fine" boy there's a subjective answer.
Ask yourself this: Do you REALLY think Chrysler would've spent the money to install those if they weren't effective/ useful/ needed?
Just a thought..........
Re: Is a sway bar REALLY THAT important...? [Re: hemirdrnnr] #445609
08/22/09 11:47 AM
08/22/09 11:47 AM
SPWC Offline OP
SPWC  Offline OP
I Just got the car driveable yesterday,and took it on its maiden voyage after being parked since 1998 by the pevious owner. I am sure the sway bar bracket was broke by the P.O. as I only drove the car down a 1 mile strip at a speed of only 25-30 mph,and then back to storage due to the rains coming in.
Re: Is a sway bar REALLY THAT important...? #445610
08/22/09 12:03 PM
08/22/09 12:03 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
No doubt and I agree, hence I gave examples of what I was driving. What one person thinks is acceptible will not be to another.
I could and will turn your argument against you.
Chrysler made millions of cars WITHOUT them, clearly in those applications they felt the money spent was not justified.
My Duster handles just fine without one with modern rubber and wheels, but I still want one since I'm a corner burner and know this will flatten out the car better in the corners.
The GTX belts out in excess of 600hp to the wheels and I had no problems steering with one hand (manual steering no less) while rowing the shifter with slicks out back with 8 pounds of air inflation.
And I have owned that car since '86 with plenty of street miles under its wheels.
The owner of the wagon who posted states it is a zero performance vehicle, in **his** case I doubt he would notice it missing.
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445611
08/22/09 12:17 PM
08/22/09 12:17 PM
Az
Crizila Offline
Crizila  Offline
Az
It's a beauty! Love them old wagons.
Fastest 300
Re: Is a sway bar REALLY THAT important...? [Re: gdonovan] #445612
08/22/09 12:17 PM
08/22/09 12:17 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Certain vehicles clearly need them, as I found out a few years ago driving a ladies early nineties caravan. That thing was quite the rolly polly turd. Raised it up, started poking around underneath and found the sway bar to be broken under the frame isolater, that sneak!
Re: Is a sway bar REALLY THAT important...? [Re: buildanother] #445613
08/22/09 12:27 PM
08/22/09 12:27 PM
SPWC Offline OP
SPWC  Offline OP
Are you sure your talking about the same car? Heres pics I took of its maiden voyage
Re: Is a sway bar REALLY THAT important...? [Re: gdonovan] #445614
08/22/09 01:09 PM
08/22/09 01:09 PM
That's a real poor example, as you (I guess) are referring to dragstrip scenerio
Chrysler may have made "millions" without them but generally these were lower performance cars. My old 64 Dodge 426 (440 body) had the biggest brakes Ma made, and a swaybar. My LATER 64 440 "Golden Anniversary" which came with a 318 had puny brakes and NO swaybar (I guess Ma figured we 318 owners didn't need to stop as fast.)
OF COURSE you can drive it without, that doesn't mean it won't make a sizeable effect. It just might be, who knows??? that that wild eyed whoopa you might make sometime avoiding that stupid dear in the road---that swaybar MIGHT just be the difference as to whether you hit the deer or not, or land in the ditch.
Been there, done that.
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445615
08/22/09 01:24 PM
08/22/09 01:24 PM
Az
Crizila Offline
Crizila  Offline
Az
Actually I was referring to the 65, but the 72 could be just as nice - lots a good sheet metal there. Most wagons came with sway bars. If it's big, heavy, hauls a load, it needs and can benifit form a sway bar.
Fastest 300
Re: Is a sway bar REALLY THAT important...? [Re: Crizila] #445616
08/22/09 03:10 PM
08/22/09 03:10 PM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
is that the wagon that was on craiglist around the Payson area?
Still Broke
