Teflon Valve Seals, Ok for Street? Int and Exh? #444700
08/20/09 09:29 PM
08/20/09 09:29 PM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
Are Teflon Valve Seals, Ok for a Street engine? Good for both Intake and Exhaust?
Re: Teflon Valve Seals, Ok for Street? Int and Exh? [Re: D_C] #444701
08/20/09 09:31 PM
08/20/09 09:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Skip the teflon and use viton seals on anything that needs a seal.
Re: Teflon Valve Seals, Ok for Street? Int and Exh? [Re: goldmember] #444702
08/20/09 09:35 PM
08/20/09 09:35 PM
absolutely, i agree. save the teflon for your frying pans
Re: Teflon Valve Seals, Ok for Street? Int and Exh? [Re: D_C] #444703
08/21/09 12:25 AM
08/21/09 12:25 AM
From what I understand they are too good & on a street eng would deprive the guides of almost any oil. Strip different story.
Re: Teflon Valve Seals, Ok for Street? Int and Exh? [Re: RapidRobert] #444704
08/21/09 02:57 AM
08/21/09 02:57 AM
D_C Offline OP
D_C  Offline OP
Thanks for the replies. I found a dusty set of (16) Mopar Performance Teflon Valve Seals still in the original shrink-wrap.
Thought I'd use a couple on the AMC 304 V8 in my CJ-5 Jeep as cylinder #7 is burning oil. Did a compression check and the cylinder is Ok / same as the other seven cylinders.
Could be an intake manifold leak, bad oil ring, scored cylinder, etc.
I have some Standard cup-type oil seals and I may have some leftover Viton seals in my gaskets collection.
I received a suggestion to try to squeeze Two oil seals onto Cylinder #7 valves and see if that "fixes" the problem.
