Re: 426 hemi plug tubes(blue) from e bay
[Re: pacifica]
#444434
08/20/09 07:56 PM
08/20/09 07:56 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Is this it?
[Re: pacifica]
#444435
08/21/09 07:29 AM
08/21/09 07:29 AM
Posts: 8,882 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
yes that is the ones can you show a lil more of how thay work with out the valve cover on (if its already off) also maybe how thay fit in top of the valve cover? im gonna have to buy 2 sets (duel plug head) so is there a o ring at the top of the short peicse and a ring at top of the other where the valve cover meets? the small peicse is taped into head and just stays there? thanks for replying ralph
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#444436
08/21/09 09:51 AM
08/21/09 09:51 AM
Posts: 4,848 Memphis
HemiRick
Memphis
they are 1 piece and they are not tall enough to touch the valve cover, yes they stay in the head. They keep oil from going into the chamber when you pull a plug great idea works like it should. Yes every hemi should have them.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: toplescuda]
#444437
08/21/09 12:02 PM
08/21/09 12:02 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
When you use them, the tube still goes through the valve cover like it always does. The tube sits in the this cup. You still get a little oil running into the cylinder, just not as bad as without it.
[Re: HemiRick]
#444438
08/21/09 12:31 PM
08/21/09 12:31 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Just a little note.....If you have the new Mopar Performance / Edelbrock heads you have to clarence the head to make those seals fit.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: toplescuda]
#444441
08/21/09 02:46 PM
08/21/09 02:46 PM
Posts: 1,883 Walla Walla, WA
Hemi_Jack
Walla Walla, WA
so if i bought the blue ones im still gonna have to buy some normal tubes?(i have nothen right now)
That is correct. The tube seals as their called seal the factory tube so oil does not drain into the combustion chamber when the plugs are pulled. As was stated above you still get some oil, just not as much as without the seals.
