cylinder head welding #444426
08/20/09 06:33 PM
08/20/09 06:33 PM
ont, canada
K
kenny b Offline OP
kenny b  Offline OP
K
ont, canada
I Finally started my 440 build after working on it for the past 2 years. It's a 446 six-pack with a comp solid set-up and stealth heads. After breaking in the cam for 20 minutes I noticed some smoke from the header flanges. Antifreeze coming through the valve cover stud. I've been told that I need to remove the heads and have them welded and then tapped to stop the leak. Is this a recommended procedure and if so does anybody know of a good shop in Ontario Canada who could do this at a reasonable price.
Kenny B
Re: cylinder head welding [Re: kenny b] #444427
08/20/09 06:39 PM
08/20/09 06:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Looks like someone drilled that hole a little to deep. Just use a good sealer on the bolt and be done with it, No biggie. Stock BB heads had all the bolts going into the water on the exhausts. mike
Re: cylinder head welding [Re: Sport440] #444428
08/20/09 06:46 PM
08/20/09 06:46 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Jam a short set screw in it with some silicone sealer and be done with it.
Re: cylinder head welding [Re: The Shadow] #444429
08/20/09 07:11 PM
08/20/09 07:11 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I like your Idea better, mike
Re: cylinder head welding [Re: Sport440] #444430
08/20/09 07:43 PM
08/20/09 07:43 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
For insurance I'd also treat the engine with Moroso Ceramic Seal. Follow the directions on the bottle. You won't be disapointed.
Re: cylinder head welding [Re: Maximus_Wedges] #444431
08/20/09 07:45 PM
08/20/09 07:45 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
JB weld on a stud would take care of that too. Just remember the stud isnt coming back out
