68 Dart turn signal switch #444236
08/20/09 01:40 PM
08/20/09 01:40 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
anyone know of a source for a 68 Dart turn signal switch? mine, being 40 years old, is very brittle and the plug on the end is almost completely gone. it wont plug into my harness at all. any ideas on where to find one? i know year one has them, but theirs dont have the plastic connector on the end of them. thanks for the help!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 68 Dart turn signal switch [Re: GTSDart340] #444237
08/20/09 01:48 PM
08/20/09 01:48 PM
If the connector is the only part of it that's bad you might consider soldering in your wires on another type of connector on both halves. R&Ring the TS switch/harness is a pain if you can avoid it.
Re: 68 Dart turn signal switch [Re: RapidRobert] #444238
08/20/09 01:59 PM
08/20/09 01:59 PM
Laveen, Arizona
Laveen, Arizona
the whole thing needs replacing. the plastic on all of it is very brittle and falling apart.
Re: 68 Dart turn signal switch [Re: GTSDart340] #444239
08/20/09 05:04 PM
08/20/09 05:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried the local parts stores? You could get lucky.
Re: 68 Dart turn signal switch [Re: stumpy] #444240
08/20/09 08:15 PM
08/20/09 08:15 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
RockAuto has them-
1968 DODGE DART 3.7L 3687cc 225cid L6 (B) : Electrical-Switch & Relay : Turn Signal Switch
DORMAN Part # 49305 More Info {HELP! - Carded}
wo/Tilt Wheel $12.41
Re: 68 Dart turn signal switch [Re: Spike] #444241
08/21/09 12:29 AM
08/21/09 12:29 AM
Laveen, Arizona
Laveen, Arizona
that dorman part number is just the canceling cam, not the whole switch. no parts stores that i can find have the whole switch.
Re: 68 Dart turn signal switch [Re: GTSDart340] #444242
08/21/09 12:41 AM
08/21/09 12:41 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I can get one through a local store here. Something like $75. The store that has them is associated with Car Quest, but they also deal with specialty companies.
