Page 2 of 6 1 2 3 4 5 6
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443787
08/20/09 02:55 PM
08/20/09 02:55 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I tried for 2 years to get rid of that off-idle bog and gave up in the end. The 750 eddy carbs are famous for it, try doing a search around other performance car forums. I tried every mod I read about and although I made some improvement I never did get rid of the bog completely. I bought a double pumper in the end. I've heard that the Thunder series AVS style carbs don't duffer with the same problem. They would still give you that stock look and an 850cfm is available..
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Mick70RR] #443788
08/20/09 04:29 PM
08/20/09 04:29 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
I'm surprised nobody has mentioned idle mixture screws yet. Where are they set at. Maybe on a stock cammed engine the normal book setting of 1.5 turns may work but on all my stuff 2.5 or 3 is fairly common and helps with off idle stumbles on automatic cars. I'm sure stick cars would benefit as well.
don.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: MoparDonny] #443789
08/20/09 04:45 PM
08/20/09 04:45 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Just went through this with an 800 eddy. If the car has a bigger cam and poor vac at idle you will get a stumble. First step is a recalibration kit. Get a vac reading at idle. Change the metering rod springs to the color coded set that meets your vac level. If cam is real big and real low vac bump up the initial timing to 18 to 22 degree's and recurve your dist. Mine also ran pretty good with an 850 holley DP. Holley does nopt use vac in the idle circut. Eddy does. Once i cured the stumble i found the eddy was much nicer on a street car then the holley and doesn';t leak fuel every where.;
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: MoparDonny] #443790
08/20/09 04:49 PM
08/20/09 04:49 PM
Dougsmopars Offline
Dougsmopars  Offline
with a big cam there isn't enough vac to hold down the metering rods during idle. They stay up at full rich. The air/fuel screws do little if anything in this condition. I've only seen this problem with eddies when installed on big cam motors. Mine only had 7 inches of vac at idle in park and 3 to 4 inches at idle in gear. Now with initial timing set at 20 car runs super with no stumble. But did need to recurve the mech advance in distributor to keep total at 38 degrees
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Dougsmopars] #443791
08/21/09 09:14 AM
08/21/09 09:14 AM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Sounds good, I have a mild cam, MP purple .474/280 (if I remember correctly).
I believe I have about 10 inches ov vac at idle. I will verify me vacuum readings on Saurday.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Dougsmopars] #443792
08/21/09 01:58 PM
08/21/09 01:58 PM
MoparDonny Offline
MoparDonny  Offline
with a 280 MP cam the mixture screws WILL need to be adjusted out.Manifold vacuum is too low to pull fuel through the idle circuit. If he has 10 inches of vacuum at idle in park I'd be suprised. Mine was a tad lower. I think the stock orange springs in a 1407 or 1408 Eddy may be a little stiff. I think I had blue stepup springs in mine but if he has over 8 inches of vac in gear the orange shouldn't create a stumble. More timing will help everything too. I welded the slots on my distributor to give me 18 initial and 34 total.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: SomeCarGuy] #443793
08/23/09 04:48 PM
08/23/09 04:48 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
If he wants it to look stock he needs to find a Carter AVS or second choice would be the Eddy AVS.
He should get the EDDY AVS , the preformer RPM 750 HAS ISSUES ...
anyone ever compare the size of the squirters on an original AVS to the ones on the EDDY ??
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: JohnRR] #443794
08/23/09 06:04 PM
08/23/09 06:04 PM
Dougsmopars Offline
Dougsmopars  Offline
I have the thunder AVS. It has same issue with big cams as regular Eddy carb. It's a vac issuse in the idle circut.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Dougsmopars] #443795
08/23/09 06:59 PM
08/23/09 06:59 PM
Orange County, CA
Mike H Offline
Mike H  Offline
Orange County, CA
I have the same problem with a new Edelbrock 1406 on a very mild cammed 383 4-speed Challenger. The car is simply no fun to drive. Where do you get these "recalibration kits"?
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Mike H] #443796
08/23/09 07:08 PM
08/23/09 07:08 PM
Dougsmopars Offline
Dougsmopars  Offline
i got mine from summit. You shouldn't be having any trouble with a 4 speed? And a mild 383? What cam? Only seen this problem in big cam motors. Did you try moving the excelerator pump arm to next hole? Eddies have this problem with very low vac readings. Have you checked other things like timing?
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Dougsmopars] #443797
08/23/09 08:33 PM
08/23/09 08:33 PM
NJ
Annie Offline
Annie  Offline
NJ
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Annie] #443798
08/23/09 09:12 PM
08/23/09 09:12 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
I must be the only #1407 Edelbrock 750 cfm AFB carb owner that's happy with their carb. It's 2 yrs old with no problems & very good performance.
Installed a $6 manual hand choke last week and now even starts easy when sitting for a week.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: MY340] #443799
08/24/09 12:03 AM
08/24/09 12:03 AM
U.S.S.A.
U.S.S.A.
Even a blind squirrel finds a nut ... there are also those that say they have NEVER been screwed over by Frank Mitchell or Jim Pattie
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: JohnRR] #443800
08/24/09 02:38 AM
08/24/09 02:38 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I can pull some threads if need bee - Just let me know , and trust me i talk from experience with the 1407/1411 paper weight about the off idle - And then if you fix that you still have a carb that doesnt perform PERIOD !!!
Some great quotes
Now, in regards to the 750 version, just SAY NO! The carb is a slug. It has the worst signal of anything we have ever tested/dynoed, and is just not an efficient or powerful carb. In plain words it is a . censored
The 500-600cfm versions are great, the 750cfm is unworthy of being on an engine.
Best Regards,
Sam - Pres/CEO
Century Performance Center, Inc.
383 Dyno in "Moparts Tech Archives"
All the aftermarket carbs tested ran fine with the stock calibration except one...the EDELBROCK 750, #1407. this one ran very poorly.....it didnt really do anything well. it was just flat out lean everywhere. idle, part throttle cruise, WOT...and it didnt like to take a load at all. when getting ready to start a pull and going to full power, the motor would fall right on its face, then try to recover....finally recover, and then you could start the pull.
i found this to be pretty interesting because i also had on hand a Carter AFB 750 manual choke version which ran perfectly fine everywhere.
decent throttle response, good part throttle cruise A/F ratios, decent idle A/F ratio with the mixture screws out only 2 turns, and the WOT A/F ratio was right where it should be, and it had a pretty flat fuel curve as well.
i was running short on time, so i just continued on my testing of other things. when i was done for the night i pulled apart the Ebrock carb to see if someone had recalibrated it. this is not a new carb, but was pulled from my friends 396 Chevy yesterday morning. he's been running on the street, and didnt really indicate there was any kinds of problems with it, but there was an indication that another friend of his may have changed some jets or something.
well....that was not the case. it had all the stock jets, rods, and springs, and had no dirt or debris inside. the calibration was just that far off from ALL the other aftermarket carbs.
IMO, the Ebrock carbs are set up for motors that are much milder than what most people are building. well, most people i know anyway
anyway....back to the trenches.....
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: bee1971] #443801
08/24/09 08:12 AM
08/24/09 08:12 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
You guys are so funny!
Maybe my Edelbrock 750 thinks it's a Holley?
You know like a wolf in sheeps clothing.
Plus my mild combo runs high 12's with slicks and as the previous owner included several times slips with the receipts.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443802
08/24/09 08:32 AM
08/24/09 08:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
want it fixed? put the Holley back on. Don't know why people like to use that 750 Eddy on a BB mopar...
Coming soon!!!!
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Mr.Yuck] #443803
08/24/09 09:09 AM
08/24/09 09:09 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I have had at least three vehicles that somebody put that junky carb on. I just shake my head in disgust.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: MY340] #443804
08/24/09 09:48 AM
08/24/09 09:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
put a holley 750DP and it'll run 2 tenths better....maybe more. If it doesn't I'll buy you a case of your favorite beverage.
Coming soon!!!!
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Mr.Yuck] #443805
08/24/09 11:18 AM
08/24/09 11:18 AM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Wow lots of activity here over the weekend!
I ran the car on Sunday, intake vacuum was 8-9 inches of vacuum at 700 rpm low idle. I moved the mixture screws out an additional 1/2 turn (now 3 turns out), and switched the vacuum advance to the full vacuum fitting, instead of the ported fitting, and the car seemed to run slightly better, but not much. I've been reading the Edelbrock manual and looking for direction there as well, lots of info and combo's for tuning, but no mention (That I found) on off-idle changes.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443806
08/24/09 11:39 AM
08/24/09 11:39 AM
U.S.S.A.
U.S.S.A.
I would put it back to the ported position or you'll have to much timing when it's not needed .
