Page 4 of 6 1 2 3 4 5 6
Re: Best Intake for a Street 383 [Re: InViolent] #44290
08/28/07 01:38 PM
08/28/07 01:38 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
OK...but if you look at what you can do with your mill for the old "bang for the buck" premise, a 4bbl on top of the RPM is WINNER IMHO.
Best bang for the buck looks to be a $75 25 year old used torker and 850 holley.
Re: Best Intake for a Street 383 [Re: Banzaiii67] #44291
08/28/07 01:39 PM
08/28/07 01:39 PM
Los Angeles, CA
Freiburger Offline OP
Los Angeles, CA
..no kidding. I figured the Weiand Team G intake to be one of the better ones listed.
Team G sucks, I had it on a 383 w/ the large summit cam and it was horrible, i ended up putting a edelbrock performer intake and it ran a lot better. This test just proved my feeling for weiand products.
For what it's worth, the Weiand intakes we tested are really old designs. The company is currently revamping most of its intakes, and the Chevy stuff we've seen from them so far is really good.
DF
Re: Best Intake for a Street 383 [Re: Freiburger] #44292
08/28/07 01:41 PM
08/28/07 01:41 PM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
DF
Have the fixed their narley casting?
Re: Best Intake for a Street 383 [Re: Banzaiii67] #44293
08/28/07 01:44 PM
08/28/07 01:44 PM
Los Angeles, CA
Los Angeles, CA
Yes.
I was at the old Weiand foundry once. Wow. Lots of legacy there.
DF
Re: Best Intake for a Street 383 [Re: Freiburger] #44294
08/28/07 01:56 PM
08/28/07 01:56 PM
AndyF Offline
AndyF  Offline
One thing that is tough (impossible?) to test on the dyno is the throttle response. I suppose the shape of the torque curve gives an indication but it isn't he whole story. The big single planes can make good torque on the dyno but sometimes on the street they have a hole in the throttle response. I've found that the Performer RPM really works on the street even if it gives up a few ponies on the top end. I bet the factory six pack setup also works great on a mild motor.
I did a manifold test for PHR a few years back where we tested the Performer RPM against the Victor 383 on my low deck 470 motor. The Victor made a couple of more hp than the RPM on the chassis dyno but it was a dog compared to the RPM in the "punch from a roll" test. The RPM would smoke the tires at will while the Victor had a bit of a bog.
One thing I want to do is to try to run a Dominator on my street car with a dual plane intake. I want to see if I can actually tune a Dominator to work at part throttle and still make the power on the top end. I wish someone made a BB Mopar intake that was dual plane with a 4500 flange but nobody does. I always liked that old C454 intake that Edelbrock made for the BBC motor.
Re: Best Intake for a Street 383 [Re: AndyF] #44295
08/28/07 01:58 PM
08/28/07 01:58 PM
Los Angeles, CA
Los Angeles, CA
The Offy 360 we tested had a 4500 flange. Obviously, the 4500 carb offers no advantage that the intake itself can't tear down.
DF
Re: Best Intake for a Street 383 [Re: Banzaiii67] #44296
08/28/07 03:19 PM
08/28/07 03:19 PM
DF
Lol. I've got an old Weiand Team G intake for 383(not currently on motor) and it is a bit of a rough casting appearance wise. Even the floor of the plenum is grainy enough looking that I always wonderred if it might be a bit porous once engine was heated up.
Re: Best Intake for a Street 383 #44297
08/28/07 03:42 PM
08/28/07 03:42 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
i have the rpm on my 383 now. i am about to start spraying it though. wont i see a better gain using a single plane like the M1.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Best Intake for a Street 383 [Re: juicedcuda] #44298
08/28/07 03:52 PM
08/28/07 03:52 PM
Los Angeles, CA
Los Angeles, CA
People tell you not to use a dual-plane with nitrous, mostly due to cylinder-to-cylinder distribution issues. Me, I've run 150-175hp shots through a lot of dual-planes with no issue. More hp than that and I'd start to pay a lot more attnention.
DF
Re: Best Intake for a Street 383 [Re: Freiburger] #44299
08/28/07 04:10 PM
08/28/07 04:10 PM
Missouri
P
petty43 Offline
petty43  Offline
P
Missouri
Do you have any numbers on a stock 4 barrel 383 intake?
1968 Satellite RR Copy Cat My Fleet
Re: Best Intake for a Street 383 [Re: Freiburger] #44300
08/28/07 04:12 PM
08/28/07 04:12 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Perfect timing, David; this is just the thing to make you go on the "magazine" thread. Still lots of useful stuff going on, obviously.
We also had a recent thread on the viability of a six pack on a stroker LA, so although we can't make direct comparisons, this is interesting in that context as well.
I look forward to buying the mag and reading the rest of the article. Good work.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Best Intake for a Street 383 [Re: Freiburger] #44301
08/28/07 04:13 PM
08/28/07 04:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
well i called the big loser right on , but thats only going off info i read on the internet ..
i'm impressed wit hthe numbers from the DP4B , i'm glad i recently bought another one .
Re: Best Intake for a Street 383 [Re: bacaruda] #44302
08/28/07 06:29 PM
08/28/07 06:29 PM
Fort Morgan
1OFNONE Offline
Has been a member for quite a few years, so relax.
1OFNONE  Offline
Fort Morgan
1OFNONE how does that STR-14 run compared to say a Holley SD,M1, Torker? Any tests or dyno?
I read somewhere that stock for stock the STR is a 30 horse crutch over a good single plain.
There are a few guys that really know how to tune and modify one to run really well. I know the basics and thats it.
After I get my suspension tuned right I will put a good single plane and a 850 on it and then I will post the findings. Not till next year.
So the bartender says to the horse " Gee, Why the long face?"
Re: Best Intake for a Street 383 [Re: 1OFNONE] #44303
08/28/07 06:41 PM
08/28/07 06:41 PM
Fort Morgan
1OFNONE Offline
1OFNONE  Offline
Fort Morgan
Thanks for all the compliments on my street car. I have alot of fun driving it.
I wanted the drug out of a barn vintage drag car look.
Thanks again guys.
Maybe I will send some photos into a magazine.
Re: Best Intake for a Street 383 [Re: 1OFNONE] #44304
08/28/07 07:33 PM
08/28/07 07:33 PM
MO
cdp Offline
cdp  Offline
MO
Good thread. I just recently picked up a DP4B and I'm going to run it on my 70-Bee with a 383/4spd combo. I hope the Comp. XE274 isn't too much for a mild build with stock exhaust.
any opinions on that?
Re: Best Intake for a Street 383 [Re: Freiburger] #44305
08/28/07 11:10 PM
08/28/07 11:10 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Dave - Can you provide the torque and HP curves vs RPM for the different intakes?
Thanks,
Ron
Re: Best Intake for a Street 383 [Re: Ronnman] #44306
08/29/07 02:45 AM
08/29/07 02:45 AM
Los Angeles, CA
Los Angeles, CA
They all made peak torque around 4,000 and peak hp around 5,900. Sorry, I can't type 15 different full curves onto the message board. Maybe one or two. What are you interested in?
DF
Re: Best Intake for a Street 383 [Re: Freiburger] #44307
08/29/07 05:59 AM
08/29/07 05:59 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
We have a winner: "I'll put the overall average TQ and Hp on the 6bbl, then the RPM, then the Torker."
rpm.
2500-6000 AVG
INTAKE LB-FT HP
Six Pack 428 348
Torker 427 348
Perf RPM 425 346
Victor 383 425 346
M1 single 424 345
1x4 tr 425 346
TM6 424 345
DP4B 424 344
Performer 422 341
Action Plus 421 341
Street Dom 421 344
Team G 409 334
Offy 360 406 338
Offy 2x4 408 330
Offy DP 404 327
What's interesting is there is only about a 5% difference top to bottom.
-Daty
Re: Best Intake for a Street 383 [Re: Daty Rogers] #44308
08/29/07 06:17 AM
08/29/07 06:17 AM
Central NC
gch Offline
gch  Offline
Central NC
i was glad to see the performer post good numbers.it gets alot of bashing but shows to be a good intake for a street 383.
the street dominator did'nt carry the torch so well compared to it's rb sibling.
Re: Best Intake for a Street 383 [Re: gch] #44309
08/29/07 12:24 PM
08/29/07 12:24 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
2500-6000 AVG
INTAKE LB-FT HP
Six Pack 428 348
Torker 427 348
Perf RPM 425 346
Victor 383 425 346
M1 single 424 345
1x4 tr 425 346
TM6 424 345
DP4B 424 344
Performer 422 341
Action Plus 421 341
Street Dom 421 344
Team G 409 334
Offy 360 406 338
Offy 2x4 408 330
Offy DP 404 327
From the Street Dominator to the Six Pack there is a difference of 7 #s of torque and 4 HP
Like anyone will notice that seat of the pants on the street - Sounds like all good intakes on average
However what makes the most HP and Torque say around 5500 - 5800 or even 6000 rpms were most of us might shift gears on our street 383 motors ???
I bet the Street Dominator is close to the top
I would like to see exact #s down low and exact #s at 5500 6000
Thats the great thing about the Street Dominator
Decent #s down low for a single plane(Right there on average with the best dual planes)but it really shines on top i bet say 5500 - 6000 rpms
Scott
THANX FOR ALL THE GREAT INFO - GOOD JOB BY THE WAY !!!
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
