Page 1 of 3 1 2 3
what is the purpose of a ballast resistor? #443002
08/19/09 03:40 PM
08/19/09 03:40 PM
new jersey
copper74 Offline OP
copper74  Offline OP
new jersey
what is the purpose of the ballast resistor? can they be jumped?
Re: what is the purpose of a ballast resistor? [Re: copper74] #443003
08/19/09 03:42 PM
08/19/09 03:42 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
1. To reduce voltage
2. I suppose, if you don't want your voltage reduced...
Down to just a blue car now.
Re: what is the purpose of a ballast resistor? [Re: copper74] #443004
08/19/09 03:42 PM
08/19/09 03:42 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
for coils not designed to take battery voltage.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: what is the purpose of a ballast resistor? [Re: copper74] #443005
08/19/09 03:44 PM
08/19/09 03:44 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
they are used to reduce the voltage
to 9 volts going into the coil
i believe
they can be jumped but not for a long period of time..
alot of people eliminate them with a different ingition system.
Re: what is the purpose of a ballast resistor? [Re: copper74] #443006
08/19/09 03:56 PM
08/19/09 03:56 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
To constantly fail thus requiring you to keep a spare in your glove box.......at least thats what I have always been told
Re: what is the purpose of a ballast resistor? [Re: copper74] #443007
08/19/09 03:59 PM
08/19/09 03:59 PM
Huntsville, Ala
sparky Offline
sparky  Offline
Huntsville, Ala
To limit current to the coil. Yes they can be jumped and watch the coil leak its oil...
1978 Lil Red Express
Re: what is the purpose of a ballast resistor? [Re: 71sat440] #443008
08/19/09 04:00 PM
08/19/09 04:00 PM
the house on the left.
cogen80 Offline
cogen80  Offline
lol. isn't that the truth
Re: what is the purpose of a ballast resistor? [Re: copper74] #443009
08/19/09 04:03 PM
08/19/09 04:03 PM
Brookline NH
Tesla_HV Offline
Tesla_HV  Offline
Brookline NH
Automotive coils are current-driven devices. In the days of points, if the ignition system were left powered up with the points in the closed position (the key left on with the engine not running), the coil would effectively short out the battery and the coil would overheat. The ballast is a series resistor which limits the current in the coil. The ballast resistor also drops some of the voltage but voltage reduction is not its primary function.
Re: what is the purpose of a ballast resistor? [Re: cogen80] #443010
08/19/09 04:15 PM
08/19/09 04:15 PM
Pennsylvania
W
WingedSixBBL Offline
W
Pennsylvania
Only 1 spare? I keep 3 in each car. Ever put one on in a rainstorm, along the side of the road, only to find out the "new" one was a P.O.S.?
Re: what is the purpose of a ballast resistor? [Re: WingedSixBBL] #443011
08/19/09 04:33 PM
08/19/09 04:33 PM
Frozen Wastelands, Ontario, Ca...
Dr Lebaron Offline
Dr Lebaron  Offline
Never had a ballast resistor problem in my 30yr Mopar life.
Now every 50,000 miles or when I get a used car I've replaced them just for the heck of it.
Used to all kinds of free ones in the package at the wreckers.
Re: what is the purpose of a ballast resistor? [Re: Dr Lebaron] #443012
08/19/09 04:50 PM
08/19/09 04:50 PM
toledo, ohio
plasticfantastic Offline
toledo, ohio
to resist ballast??
Re: what is the purpose of a ballast resistor? [Re: plasticfantastic] #443013
08/19/09 04:58 PM
08/19/09 04:58 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
You must be the only one...LOL
Re: what is the purpose of a ballast resistor? [Re: cudaboy] #443014
08/19/09 05:10 PM
08/19/09 05:10 PM
And now, for the CORRECT answer. Ballasts change resistance with current as they heat and cool, and thus provide a sort of buffer for the coil. Coil current will be different at higher and lower RPM.
But the REAL nitty gritty reason is "easier starting."
A normal system runs close to 14V, and Mopar coils used to run anywhere from 8-10V AT THE COIL at the bottom end of the ballast.
When you crank the engine for start, the switch bypasses the resistor, so the coil STILL GETS about 10V--so a nice hot spark for starting.
This is something the ol' 6V cars never had.
Re: what is the purpose of a ballast resistor? #443015
08/20/09 01:46 AM
08/20/09 01:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats the best answer. The ballast reduces the current flow thru the coil at low speeds and keeps the coil from overheating. As was said the coil can handle more amperage but not for long periods of time. So at idle and low eng speeds the points have more time to be closed and thus the current heats the ballast up and causes it to have more resistance and drop current flow at lower eng speeds when full coil output is not needed. When you go faster and speed the eng up the points have less time to be closed so the ballast cools down some and the resistance drops causes more current to flow thru the coil and letting the coil output higher when it is needed at higher eng speeds. And when cranking the ign system needs full output to help start the eng so the ign switch bypases the ballast and gives full battery volts to the coil while cranking. Ron
Re: what is the purpose of a ballast resistor? [Re: 383man] #443016
08/20/09 01:53 AM
08/20/09 01:53 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I thought it was there to burn the out of your finger the first time you touch one...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: what is the purpose of a ballast resistor? [Re: Tesla_HV] #443017
08/20/09 01:58 AM
08/20/09 01:58 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Aftermarket ignitions like the multi-spark boxes of the ready2run distributors have current-limiting circuitry in them so you don't need to run a ballast anymore.
Re: what is the purpose of a ballast resistor? [Re: copper74] #443018
08/20/09 02:27 AM
08/20/09 02:27 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Also, along with the capacitor, helped protect the points in the old style distributors.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: what is the purpose of a ballast resistor? [Re: Tesla_HV] #443019
08/20/09 08:36 AM
08/20/09 08:36 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
I agree with this.
i dont agree with the post that says a ballast resistor is supposed to change resistance with temperature. yes, resistors DO change resistance as the temperature changes but I dont believe thats what makes a ballast resistor a ballast resistor. and i dont believe this is a something the system needs or is desirable- its a physical propert y of the resistor and I bet, if they could make a more stable resistor as a reasonable cost, they would but since slight changes in resistance due to temperature changes isnt critical, they dont worry about it
afaik, a ballast resistor is just a big resistor that can handle more power than your typical 1/4 or 1/8 watt resistor. Ballast resistors need to be big and bulky to dissipate heat because the current draw through the coil generates lots of heat. as the resistor will limit the current to keep the coil from melting, the ballast resistor heats up and needs to be big and stout so IT wont melt as well.
Re: what is the purpose of a ballast resistor? [Re: DaytonaTurbo] #443020
08/20/09 08:52 AM
08/20/09 08:52 AM
Blanchard, OK
Real-Fury Offline
Real-Fury  Offline
Blanchard, OK
Been thinking of switching out my points for one of the electronic ignition modules and new coil. If I do this will I discard the ballast resistor?
Butch
Re: what is the purpose of a ballast resistor? [Re: Real-Fury] #443021
08/20/09 11:00 AM
08/20/09 11:00 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Well just out of curiosity, what did GM and Ford use so as not to burn out coils ????
Page 1 of 3 1 2 3
