318 and 360 motor mount, the same? #44218
08/27/07 04:19 PM
08/27/07 04:19 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I was wondering if a 318 and360 have the same mounts? I always thought the driver side mount was different. does the year make a difference 68-79 ?
thanks
Re: 318 and 360 motor mount, the same? [Re: dirt] #44219
08/27/07 04:24 PM
08/27/07 04:24 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
They are not the same. However you can use the 318 mount which you can actually buy on a 360 with some spacers. I believe its about .250 in. spacer.
Back in the swing of things at Painless again! Great to be back!
Re: 318 and 360 motor mount, the same? [Re: BJS racing] #44220
08/27/07 04:27 PM
08/27/07 04:27 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I just got a new mount from napa and they list the same # for both 318 and 360. it dosent fit at all. however it does seem to fit on an old 318 i have laying around. so i gotta shim it?
Re: 318 and 360 motor mount, the same? [Re: dirt] #44221
08/27/07 08:25 PM
08/27/07 08:25 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
sonds like you are talking about the rubber isolator and he is talking about the bracket bolted to the block.
5549 post on old board
Re: 318 and 360 motor mount, the same? [Re: 05dakota] #44222
08/27/07 09:13 PM
08/27/07 09:13 PM
5thAve Offline
5thAve  Offline
If you buy a 360 one you get a 318 one now.
Re: 318 and 360 motor mount, the same? [Re: 5thAve] #44223
08/27/07 09:52 PM
08/27/07 09:52 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Yeah to use a 318 mount on a 360 you've gotta shim it at the back hole. I've done this on Truck brackets without issues. I just threw an old nut in there to take up the space.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: 318 and 360 motor mount, the same? [Re: MoPar Jamie] #44224
08/28/07 02:32 PM
08/28/07 02:32 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Pic....
Re: 318 and 360 motor mount, the same? [Re: Reggie] #44225
08/28/07 03:16 PM
08/28/07 03:16 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Great picture! This comes up a lot, can the mods sticky this?
Re: 318 and 360 motor mount, the same? [Re: RodStRace] #44226
08/28/07 03:25 PM
08/28/07 03:25 PM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
A-body 1968-1972 340-360 uses 1 drivers side steel bracket. here is a pic(Will also fit 1967 A-body V8 k-frame)
Re: 318 and 360 motor mount, the same? [Re: Joesixpack] #44227
08/28/07 03:30 PM
08/28/07 03:30 PM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
1967-1972 A-body 273-318 uses this mount on the drivers side and it wont bolt to the 340-360 block as you can see the ear is missing on the mount where the ear is on the 340-360 block.
Re: 318 and 360 motor mount, the same? [Re: Joesixpack] #44228
08/28/07 03:36 PM
08/28/07 03:36 PM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
now on a 66-72 B-body/70-74 E-body they have 1 drivers side 273-318 mount that can be used on a 340-360 block. the bracket ID is wider than the blocks ear OD so there is a small (.250)gap that can be filled with washers,and or a spacer. here is the 273-318 B/E drivers side.
Re: 318 and 360 motor mount, the same? [Re: Joesixpack] #44229
08/28/07 03:37 PM
08/28/07 03:37 PM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
340-360 B/E body is shown here on right hand side.note how it is narrower at the top between the tips as it matchs the narrower spread width of the 340-360 block ears.
