Re: 360 Stroker info please...
[Re: MNobody]
#442263
08/18/09 07:53 PM
08/18/09 07:53 PM
RapidRobert
a day or 2 ago there were 2 good rod recommendations for reasonable money one was scat & the other was a rebuilt one w Milodon bolts iirc(cant remember who) & they'll be 6.123". The dist will fit & I haven't got that far but I believe no clearance issues.
[Re: MNobody]
#442267
08/18/09 08:08 PM
08/18/09 08:08 PM
RapidRobert
Mine will be a daily driver & I'm using some badger cast flattops that I already had but if I didn't have them probably the old standby KB & their not cheap either. I would get quench so you can run a higher CR on your intended fuel
[Re: MNobody]
#442268
08/18/09 08:13 PM
08/18/09 08:13 PM
Posts: 20,831 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
How much clearance do they need? Thanks.
I ground on mine enough so that a toothpick could slide inbetween the rods and the block. The total amount needed to be ground away is pretty small.
Also make sure you buy radiused connecting rod and main bearings.
http://www.moparts.org/Tech/Archive/smallblock/16.html
[Re: Neil]
#442269
08/18/09 08:30 PM
08/18/09 08:30 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
scat i beam will fit without any grinding...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Neil]
#442273
08/18/09 09:59 PM
08/18/09 09:59 PM
Posts: 7,506 Az
Crizila
Az
It will be very difficult to reach your 500HP goal with those heads,even fully ported - and that intake manifold won't be much help getting there ether. I'd say 400 to 425 with the correct cam choice - maybe.
Fastest 300
[Re: MNobody]
#442278
08/19/09 03:52 AM
08/19/09 03:52 AM
500 h.p. 408 stroker on a budget firstoff whats your budget???...
#442281
08/19/09 10:25 AM
08/19/09 10:25 AM
Posts: 4,884 Michigan
MNobody
Cheap as possible but still dependable, it will be street driven but i want her to run ![](/ubbthreads/images/graemlins/drive.gif)
