4.0 fuel pump, would it just quit? #442154
08/18/09 04:09 PM
08/18/09 04:09 PM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
96 Jeep Cherokee 4.0/automatic, 167,000 miles, ran great.....went to crank it this morning. Acted like it didnt' want to fire at all. I didn't notice the pump humming like it noramally does. So, I took off the rubber hose from the sending unit to the filter, turned the switch and got nothing. I am going to go out on a ledge here and say fuel pump.....but it gave NO warning sign what-so-ever......is that normal? Any other ideas?
Re: 4.0 fuel pump, would it just quit? [Re: BarryBum] #442155
08/18/09 04:12 PM
08/18/09 04:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Hook the hose back up and slap the bottom of the tank with a mallet while somebody cranks it over. If it runs then, the pump is most likely on it's way out.
Re: 4.0 fuel pump, would it just quit? [Re: buildanother] #442156
08/18/09 04:23 PM
08/18/09 04:23 PM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
Tried the beating thing, still wouldn't crank. I did notice that the low fuel light comes on after you try to crank it.....it normally comes on as soon as you turn the switch on. But now it don't come on til you try to crank it, and its not low on fuel, its got about 1/4 tank.
Re: 4.0 fuel pump, would it just quit? [Re: BarryBum] #442157
08/18/09 06:14 PM
08/18/09 06:14 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Could be a relay, but more likely the pump. Yes, they can just "go".
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
