Kabooom... back fire thru carb #441615
08/17/09 10:56 PM
08/17/09 10:56 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I thought I would share this with you since its something I have never seen, heard about or ever experienced..
Being a skool boy learning this nitrous stuff.. I made a silly little error that could have been quite costly.. Luckily, the motor seems to be ok..
In the pits this last weekend, we hooked up the bottle, put the warmer on it and got it up to temp.. For some dumb reason, I decided to purge it by using the micro-switch on the gas pedal.. I know.. I know.. what was I thinking
An hour or so later, they called my number for first round time trials and I hopped in the car and was all excited to break new ET's and MPH...
I crank over the motor and KABOOOOM !!! people 6 rows away ducked for cover.. The ol nitrous back fire..
Well.... we needed to put all the rubber vacuum lines back on the carb and then decided to fire it up to see if there was any damage.. the motor fired right up, but shot up to 3500 rpm.. Turned off the motor and looked everything over once again.. turned on the fuel pump, no fuel running down the carb.. so we fired it back up... right up to 3500 rpm and fuel was gushin into the secondaries..
Decided to miss the 1st round and pull off the carb and to my surprise, the backfire bent both butterflies on the secondary almost a good 70 degrees pointing upward... which explains why the motor raced to 3500 rpm...
We flattened them back out and the motor seems to have survived without any issues.. However this was sooooo freak, I thought I would share it with you guys...
Re: Kabooom... back fire thru carb [Re: Jeepmon] #441616
08/17/09 11:00 PM
08/17/09 11:00 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Wow, that could have been much worse. Glad to hear no one was hurt and your motor appears to be unharmed.
Re: Kabooom... back fire thru carb [Re: Jeepmon] #441617
08/17/09 11:04 PM
08/17/09 11:04 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
That ought to teach you...........now get that crap off of
there and do it the right way.
Re: Kabooom... back fire thru carb [Re: WILD BILL] #441618
08/17/09 11:06 PM
08/17/09 11:06 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Thats crazy force behind those NOS booms...
Re: Kabooom... back fire thru carb [Re: Jeepmon] #441619
08/17/09 11:11 PM
08/17/09 11:11 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You guys need to know this stuff is NASTY and to treat it with a lot of respect. You could have hurt yourself or somebody else. It will lay in a manifold for a long time and this is exactly what happens.
Re: Kabooom... back fire thru carb [Re: 70dusterjohn] #441620
08/17/09 11:19 PM
08/17/09 11:19 PM
Kauai, Hawaii
452RT Offline
452RT  Offline
Kauai, Hawaii
I was inside my car and it sounded like a M80. I was glad you figured it out.
Hope you enjoyed your time up north here in the Great NW.
I would like to make it down south next year and race some of you guys, maybe even Bill or Al.
Re: Kabooom... back fire thru carb [Re: S/ST 3040] #441621
08/17/09 11:26 PM
08/17/09 11:26 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
What is the right way,go slow.Give me a break.Not everyone is 90 years old on here.
Re: Kabooom... back fire thru carb [Re: 8secDart] #441622
08/17/09 11:38 PM
08/17/09 11:38 PM
S/ST 3040 Offline
S/ST 3040  Offline
Then, hopefully most of us still have a sense of humor.
Re: Kabooom... back fire thru carb [Re: 70dusterjohn] #441623
08/18/09 03:37 AM
08/18/09 03:37 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow Don. Glad that was it for the problem. That laughing gas is some dangerous stuff. Good luck , bud..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Kabooom... back fire thru carb [Re: sunroofgtx] #441624
08/18/09 07:58 AM
08/18/09 07:58 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
A friend of mine had a pretty severe backfire in his stang years ago and it did lots of damage. A solenoid hung open in the shutdown area and it died, so he went to fire it up on the return road and BOOM. Hood, intake, throttle body, ring lands on the pistons were all done for.
I have done the same thing as you have, but mine bent the primary blades and I never could get it to idle right again so I had to get a new baseplate.
68 Barracuda Formula S 340
Re: Kabooom... back fire thru carb [Re: Jeepmon] #441625
08/18/09 08:30 AM
08/18/09 08:30 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Wow
Dont feel bad, you know 100% more than me about NOS, but someday I plan to run it..So its safe to say not to purge the line through the engine at all correct?
Re: Kabooom... back fire thru carb [Re: Bob_Coomer] #441626
08/18/09 10:13 AM
08/18/09 10:13 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Wow
Never put nitrous in the motor unless its running and WOT.
Re: Kabooom... back fire thru carb [Re: S/ST 3040] #441627
08/18/09 11:57 AM
08/18/09 11:57 AM
organ
maximum entropy Offline
organ
yeah. slow like the cuda in your sig pic. what a turd.
Re: Kabooom... back fire thru carb [Re: maximum entropy] #441628
08/18/09 12:15 PM
08/18/09 12:15 PM
S/ST 3040 Offline
S/ST 3040  Offline
It is a pile.
10.74 @ 124.73
OEM heads, stock stroke 340, flat tappet, 727.........
Re: Kabooom... back fire thru carb [Re: S/ST 3040] #441629
08/18/09 12:27 PM
08/18/09 12:27 PM
Maryland
Bill_G Offline
Bill_G  Offline
Maryland
Just went through this with a friend we put the spring loaded pressure relief valve on his SM tunnel ram, get one of these it will save you money in the long run!
Bill
1970 Charger R/T 1970 Dart Swinger 340/4spd
Re: Kabooom... back fire thru carb [Re: Bill_G] #441630
08/18/09 12:46 PM
08/18/09 12:46 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Bill
What the heck is that and how does it work?
Re: Kabooom... back fire thru carb [Re: Jeepmon] #441631
08/18/09 12:49 PM
08/18/09 12:49 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The round things are rupture discs that vent the explosion.
Re: Kabooom... back fire thru carb [Re: BobR] #441632
08/18/09 05:17 PM
08/18/09 05:17 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Don... shame shame....
If you want a new engine or people to look at the car there are less dramatic ways to do it.
Re: Kabooom... back fire thru carb [Re: moper] #441633
08/18/09 05:31 PM
08/18/09 05:31 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
When we sprayed, we never had a purge set up , I just purged thru the micro switch and cranked with the Ign power off to bleed off the gas, worked every time, not as many cool points as the guys blasting out the purge valve but very stealth
Re: Kabooom... back fire thru carb [Re: emarine01] #441634
08/18/09 07:01 PM
08/18/09 07:01 PM
UK
602heavy Offline
602heavy  Offline
UK
Guess you got lucky , i sprayed a 300 shot pulling too much timing for the distributor , blew the throttle bades & boosters right off the carb mid track , set fire to the bulk head wiring & fried the hood , have since fitted a 'cap adapt'.
