Iron heads vs. Stealths #440865
08/17/09 01:46 PM
08/17/09 01:46 PM
Suffolk,VA
I
ireland383 Offline OP
I
Suffolk,VA
Why would my motor feel like it has more power with my 346 heads shaved .030 vs the new 440 source heads? It has KB 400 pistons and both heads had the same head gaskets.
Re: Iron heads vs. Stealths [Re: ireland383] #440866
08/17/09 01:55 PM
08/17/09 01:55 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Aluminum heads take more heat away from the chamber = less power. i would bump c/r up 1 to 1.5 when going to aluminum .
Re: Iron heads vs. Stealths [Re: ademon] #440867
08/17/09 02:02 PM
08/17/09 02:02 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
if everything is the same, iron heads make more power
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Iron heads vs. Stealths [Re: davesmopars] #440868
08/17/09 02:37 PM
08/17/09 02:37 PM
Suffolk,VA
I
I
Suffolk,VA
The 346's have the stock valve sizes. I thought I would benefit with the larger valves of the stealths, also the weight factor. I'm not sure how much can be shaved off the stealths with running a domed piston. I'm sure I'm close to 10 to 1 now. One other thing I thought would be better is the closed chamber of the stealths.
Re: Iron heads vs. Stealths [Re: davesmopars] #440869
08/17/09 03:04 PM
08/17/09 03:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Guys, are you kidding me? Seriously...... First off, the 346 head is an open chamber, so going to a stealth head would up the compression significantly.
Secondly, I don't even know what to say..... a stock set of 346 castings vs. a set of Stealths?? Is this a trick question? Is there something I'm missing? I'd say: no comparo. There's no way the 346 even come close.
Now, We need to know more about the combo. If you don't have the flow abilities on the intake side, or the exhaust side, to make use of the flow capabilities of the new heads, then maybe you wouldn't feel a difference ?? Tell us more about the entire combo.
Re: Iron heads vs. Stealths [Re: StealthWedge67] #440870
08/17/09 03:13 PM
08/17/09 03:13 PM
Suffolk,VA
I
I
Suffolk,VA
750 holley, Weiand dual plane, 1 3/4 hedman full length headers,727, 3.55, compcams 275DEH 219/235 @ .050 462/482
Re: Iron heads vs. Stealths [Re: ireland383] #440871
08/17/09 03:28 PM
08/17/09 03:28 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
Actual real world tests show very very little if any power loss from iron vs aluminum. I have seen several dyno tests of heads in iron and alumnium even as can be like CNC ported and there was no real world differance in the power, 2 or 3 tops on a 350 chevy. The aluminum head allows more compression, it does NOT require more compression.
As for your combo feeling weeker it could be a few things, mabey timing was not optimised for the new heads(they will need less timing) and the carb could be running lean with the extra airflow. Mabey the car is hooking better do to weight so now you can not roast the tires like you were. Mabey the tq converter needs adjusted also. Several things to look at before jumping to blame the heads. If there is a problem with the heads it would show up in a leakdown test(bad valve job).
Re: Iron heads vs. Stealths [Re: davesmopars] #440872
08/17/09 04:35 PM
08/17/09 04:35 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Power band and torque curve most likely changed. With the larger valves the bottom end torque could have changed. My 11.70 Pontiac felt like a high 13 second car because the torque curve was so flat.
Maybe butt o meter needs recalibration?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Iron heads vs. Stealths [Re: HealthServices] #440873
08/17/09 06:33 PM
08/17/09 06:33 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Give all the details of the engine. What cam? What intake? headers? convertor? gearing? carb?
Re: Iron heads vs. Stealths [Re: moper] #440874
08/17/09 06:39 PM
08/17/09 06:39 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Your running a dome piston with closed chamber heads ?? How far down in the hole are the pistons ? Ron
Re: Iron heads vs. Stealths [Re: moper] #440875
08/17/09 06:42 PM
08/17/09 06:42 PM
Suffolk,VA
I
I
Suffolk,VA
I already posted them in this thread except I left out the converter 2400 stall Thanks
Re: Iron heads vs. Stealths [Re: ademon] #440876
08/17/09 06:45 PM
08/17/09 06:45 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
This is exactly what my head builder said.
Re: Iron heads vs. Stealths [Re: 383man] #440877
08/17/09 06:46 PM
08/17/09 06:46 PM
Suffolk,VA
I
I
Suffolk,VA
Ron I sent the car back to my builder to check for vacuum leaks and to do a leak down test. I'm not sure how far down they are.
Re: Iron heads vs. Stealths [Re: 383man] #440878
08/17/09 07:02 PM
08/17/09 07:02 PM
Puyallup, WA
Puyallup, WA
http://kb-silvolite.com/performance.php?action=details&P_id=327
He's got the right piston for these heads, Ron. KB400's are more of a flat-top with a dome section above the valves only. Pretty much designed around a closed chamber head. You can run these at zero deck with closed chamber heads.
Re: Iron heads vs. Stealths [Re: 383man] #440879
08/17/09 07:06 PM
08/17/09 07:06 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Re: Iron heads vs. Stealths [Re: HotRodDave] #440880
08/17/09 07:44 PM
08/17/09 07:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I also remember reading an article where they used an identical set of aluminum and iron heads on a chevy build and they dynoed within a couple hp/torq of each other.
But, going from stock small port heads to bigger port aftermarket heads could have costed you some low end power due to a drop in port velocity. Also your new heads could be flowing enough more that you're leaning out under WOT.
Re: Iron heads vs. Stealths [Re: StealthWedge67] #440881
08/17/09 10:15 PM
08/17/09 10:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ok I should have looked at the piston first. Thanks , Ron
Re: Iron heads vs. Stealths [Re: StealthWedge67] #440882
08/18/09 11:15 AM
08/18/09 11:15 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
That's a correct statement, everything the same (ports, valves, combustion chamber), an iron head will make more power.
It takes about a 1 point increase in compression, with everything else the same, for aluminum heads to make the same power.
As fas as 346 vs Stealth, the Stealths advantages still should overcome any power loss from the use of aluminum. I'd advance the timing 2 to 4 degreees till the Stealth heads can be cut or pistons are changed. More timing can be used as a crutch till the compression is raised.
Re: Iron heads vs. Stealths [Re: B5 Bee] #440883
08/18/09 12:09 PM
08/18/09 12:09 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I would mill the 346 heads .030 and pocket port them and run them . then install a Crower 32243 cam (228/234)and a 850 Thermoquad and head to the track and lay down some mid to high 12s.
Re: Iron heads vs. Stealths [Re: B5 Bee] #440884
08/18/09 08:53 PM
08/18/09 08:53 PM
Suffolk,VA
I
I
Suffolk,VA
I'm at 10 to 1 now, you're saying go to 11 to 1 won't that put me into race fuel?
