Re: Iron heads vs. Stealths
[Re: ademon]
#440867
08/17/09 02:02 PM
08/17/09 02:02 PM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
if everything is the same, iron heads make more power
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#440868
08/17/09 02:37 PM
08/17/09 02:37 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
The 346's have the stock valve sizes. I thought I would benefit with the larger valves of the stealths, also the weight factor. I'm not sure how much can be shaved off the stealths with running a domed piston. I'm sure I'm close to 10 to 1 now. One other thing I thought would be better is the closed chamber of the stealths.
[Re: davesmopars]
#440869
08/17/09 03:04 PM
08/17/09 03:04 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Guys, are you kidding me? Seriously...... First off, the 346 head is an open chamber, so going to a stealth head would up the compression significantly.
Secondly, I don't even know what to say..... a stock set of 346 castings vs. a set of Stealths?? Is this a trick question? Is there something I'm missing? I'd say: no comparo. There's no way the 346 even come close. Now, We need to know more about the combo. If you don't have the flow abilities on the intake side, or the exhaust side, to make use of the flow capabilities of the new heads, then maybe you wouldn't feel a difference ?? Tell us more about the entire combo.
[Re: ireland383]
#440871
08/17/09 03:28 PM
08/17/09 03:28 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Actual real world tests show very very little if any power loss from iron vs aluminum. I have seen several dyno tests of heads in iron and alumnium even as can be like CNC ported and there was no real world differance in the power, 2 or 3 tops on a 350 chevy. The aluminum head allows more compression, it does NOT require more compression.
As for your combo feeling weeker it could be a few things, mabey timing was not optimised for the new heads(they will need less timing) and the carb could be running lean with the extra airflow. Mabey the car is hooking better do to weight so now you can not roast the tires like you were. Mabey the tq converter needs adjusted also. Several things to look at before jumping to blame the heads. If there is a problem with the heads it would show up in a leakdown test(bad valve job).
[Re: davesmopars]
#440872
08/17/09 04:35 PM
08/17/09 04:35 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Power band and torque curve most likely changed. With the larger valves the bottom end torque could have changed. My 11.70 Pontiac felt like a high 13 second car because the torque curve was so flat. Maybe butt o meter needs recalibration?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#440873
08/17/09 06:33 PM
08/17/09 06:33 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Give all the details of the engine. What cam? What intake? headers? convertor? gearing? carb?
[Re: HotRodDave]
#440880
08/17/09 07:44 PM
08/17/09 07:44 PM
DaytonaTurbo
Manitoba, Canada
I also remember reading an article where they used an identical set of aluminum and iron heads on a chevy build and they dynoed within a couple hp/torq of each other.
But, going from stock small port heads to bigger port aftermarket heads could have costed you some low end power due to a drop in port velocity. Also your new heads could be flowing enough more that you're leaning out under WOT.
[Re: StealthWedge67]
#440881
08/17/09 10:15 PM
08/17/09 10:15 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Your running a dome piston with closed chamber heads ?? How far down in the hole are the pistons ? Ron
http://kb-silvolite.com/performance.php?action=details&P_id=327
He's got the right piston for these heads, Ron. KB400's are more of a flat-top with a dome section above the valves only. Pretty much designed around a closed chamber head. You can run these at zero deck with closed chamber heads.
Ok I should have looked at the piston first. Thanks , Ron
#440882
08/18/09 11:15 AM
08/18/09 11:15 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
That's a correct statement, everything the same (ports, valves, combustion chamber), an iron head will make more power.
It takes about a 1 point increase in compression, with everything else the same, for aluminum heads to make the same power.
As fas as 346 vs Stealth, the Stealths advantages still should overcome any power loss from the use of aluminum. I'd advance the timing 2 to 4 degreees till the Stealth heads can be cut or pistons are changed. More timing can be used as a crutch till the compression is raised.
