Small block belt drive? #440727
08/17/09 09:45 AM
08/17/09 09:45 AM
nc
E
emarine01 Offline OP
E
nc
Whats a good belt drive rig for a stock 59* small block that cam timing can be changed with out taking apart the timing cover?
Re: Small block belt drive? [Re: emarine01] #440728
08/17/09 09:52 AM
08/17/09 09:52 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Ritter/Weber makes a really nice one....
Ritter/Weber Belt Drive
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Small block belt drive? [Re: DemonDust] #440729
08/17/09 10:01 AM
08/17/09 10:01 AM
nc
E
E
nc
Nice unit Anyone have a installed pic with a water pump on?
Re: Small block belt drive? [Re: emarine01] #440730
08/17/09 10:04 AM
08/17/09 10:04 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
You'll need Water pump spacers to use the Weber drive. I have pics, but they are on my home computer. Meziere makes them (spacers) for Tall deck applications.
Jesel also makes one, but the Weber is cheaper & uses an idler. Everything I've ever built used the Weber, so I'm not overly familiar with the Jesel.
Re: Small block belt drive? [Re: RyanJ] #440731
08/17/09 10:24 AM
08/17/09 10:24 AM
nc
E
E
nc
How thick are the spacers, Ive only got around 1/2" rad to water pump motor clearance?
Re: Small block belt drive? [Re: emarine01] #440732
08/17/09 10:29 AM
08/17/09 10:29 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
1-3
Re: Small block belt drive? [Re: emarine01] #440733
08/17/09 10:30 AM
08/17/09 10:30 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: Small block belt drive? [Re: SB449VALIANT] #440734
08/17/09 10:30 AM
08/17/09 10:30 AM
Mcallen, TX
Mcallen, TX
Re: Small block belt drive? [Re: S/ST 3040] #440735
08/17/09 10:33 AM
08/17/09 10:33 AM
S/ST 3040 Offline
S/ST 3040  Offline
Re: Small block belt drive? [Re: S/ST 3040] #440736
08/17/09 11:00 AM
08/17/09 11:00 AM
Mcallen, TX
Mcallen, TX
Re: Small block belt drive? [Re: SB449VALIANT] #440737
08/17/09 02:36 PM
08/17/09 02:36 PM
nc
E
E
nc
It appears that all the cam timing is done @ the cam gear, so there is no need to pull the balancer to change lower gear setting?
Re: Small block belt drive? [Re: emarine01] #440738
08/17/09 02:40 PM
08/17/09 02:40 PM
S/ST 3040 Offline
S/ST 3040  Offline
Correct
Re: Small block belt drive? [Re: S/ST 3040] #440739
08/17/09 03:06 PM
08/17/09 03:06 PM
nc
E
E
nc
Good pic, thankx Vic, We need one of these , seems like a great tuning tool, just gota come up with a mud cover
