Tooth off on timing chain?........ #440245
08/16/09 09:00 PM
08/16/09 09:00 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
What would be the symptoms of a timing chain being one tooth off? This is on a 360.
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440246
08/16/09 09:04 PM
08/16/09 09:04 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
loss of power. hard to start. runs like junk
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440247
08/16/09 09:26 PM
08/16/09 09:26 PM
put your marks on TDC & see where the rotor is (whether #1 or #6) it'll be way off from the underside of the dist cap terminal. More details, what happened.
Re: Tooth off on timing chain?........ [Re: RapidRobert] #440248
08/16/09 09:53 PM
08/16/09 09:53 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Already done.
We set the timing at 35* at 3,000 rpm. It has very low vacuum (9"). But if you advance the timing to 42* we can get the vacuum up to 17".
Engine has a miss between 1,800 to 2,300 rpm. The engine runs better with a lot of advance but still has that stutter.
We've ruled out vacuum leaks.
Re: Tooth off on timing chain?........ [Re: RapidRobert] #440249
08/16/09 09:53 PM
08/16/09 09:53 PM
I think if you pull the fuel pump you can feel for the slop in the chain. Does this maybe have the phenolic top sprocket? If steel, there's very little chance that it's slipped.
Quickest way, is that IF you know where the timing is supposed to be, and it's way off, it's slipped.
Take a wrench and rotate the engine cw/ ccw against the chain "slop." If it's 10* movement or more, I'd be suspecting slippage.
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440250
08/16/09 10:00 PM
08/16/09 10:00 PM
Already done.
and where was the rotor
Re: Tooth off on timing chain?........ [Re: RapidRobert] #440251
08/16/09 10:28 PM
08/16/09 10:28 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Is this a new installed timing set, or what are we working on? In all the years of working on this stuff about the only time I have seen a timing chain off a tooth is if it were installed that way. It can happen but the vast majority of the time if a chain goes south it is is because it is running on the plastic sprocket and the sprocket teeth go away and the chain literally spins on the sprocket. When this happens you will have not so cute little eye brows on the pistons very likely along with some bent valves.
Re: Tooth off on timing chain?........ [Re: RapidRobert] #440252
08/16/09 10:28 PM
08/16/09 10:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Pull the distributor cap.
Rotate the crankshaft back & forth with a socket wrench while watching the rotor.
If the timing chain is worn, you will be able to move the crank a few degrees without seeing the rotor move.
If they do not move together, replace the chain & gears.
Re: Tooth off on timing chain?........ [Re: Alaskan_TA] #440253
08/17/09 09:31 AM
08/17/09 09:31 AM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
just checked, the timing chain (new chain) is dead on. Harmonic balancer is good (didn't slip). Back fires out the carb at rapid throttle and has steady 9" of vacuum with timing set at 35 degrees at 3000. Now if we set the timing to 45 degree the vacuum is at steady 17" no popping out of the carb and the engine seems to run fine except for a miss between 1800 to 2300 RPM.Rotor points to #1 wire. Compression test is normal.
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440254
08/17/09 09:39 AM
08/17/09 09:39 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sounds like you may need to add initial timing and limit the extent of the full advance. Or is the advance locked out already?
Re: Tooth off on timing chain?........ [Re: buildanother] #440255
08/17/09 09:56 AM
08/17/09 09:56 AM
. I'd set the initial (vac gauge method) then weld (no JB ) the slots for 35 total (w vac adv disconnected) then ch the springs staying just under the pinging point @ WOT then plugging in the vac adv (if used) & adj for just under the pinging point at part throttle
Re: Tooth off on timing chain?........ [Re: RapidRobert] #440256
08/17/09 10:35 AM
08/17/09 10:35 AM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
Are you sure the harmonic balancer hasn't slipped on its rubber ring, giving you incorrect timing with the timing light?
Re: Tooth off on timing chain?........ [Re: marvo451] #440257
08/17/09 11:53 AM
08/17/09 11:53 AM
Upper Midwest
Upper Midwest
Make sure that the distributor is calibrated to be fully advanced at the RPM that you are checking the total at.
Re: Tooth off on timing chain?........ [Re: MoparforLife] #440258
08/17/09 12:31 PM
08/17/09 12:31 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
check your plug wires, I had one with a cut in the insulation and it would short out intermittentlly. it idled fine but under power you could feel the miss., almost like a timing chain studder.
Gary.
Re: Tooth off on timing chain?........ [Re: marvo451] #440259
08/17/09 01:11 PM
08/17/09 01:11 PM
Upper Midwest
Upper Midwest
He already stated above that the TDC mark is right on with piston position.
Re: Tooth off on timing chain?........ [Re: MoparforLife] #440260
08/17/09 02:45 PM
08/17/09 02:45 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
This may sound crazy but I worked as a tech for dodge dealers thru the 70's and they had a problem with the 360's, when if the motor backfired it could pop the seat off the EGR valve .Dont know if your car still has one on it but it makes that type of noise. EZ to ck...just take off the valve and look at it....the little plunger should be seated in the valve body... Just a thought
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440261
08/17/09 02:55 PM
08/17/09 02:55 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Did this happen after the chain set was replaced? I believe there was a run of spockets (sorry don't know which manufacter) that were mis-marked out of the box. It maybe worth it to degree your cam.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440262
08/17/09 04:26 PM
08/17/09 04:26 PM
I could've sworn I posted this. Just exactly how did you check this?
Re: Tooth off on timing chain?........ [Re: dustergirl340] #440263
08/17/09 05:06 PM
08/17/09 05:06 PM
columbus,ohio
P
prorunner1 Offline
super street
prorunner1  Offline
super street
P
columbus,ohio
when setting the timing did the timing marks stay steady or were they erratic?maybe the oil pump/distributor drive gear is worn.
Re: Tooth off on timing chain?........ [Re: prorunner1] #440264
08/17/09 09:57 PM
08/17/09 09:57 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
Not tryin to be a smart a$$ but double check your plug wires.
I kno it sounds too easy but... its happened to me mor than once, 6 & 8 crossed will produce similar symptoms
Let us kno what ya find,
