New motor in,got a couple of problems
#440215
08/16/09 08:06 PM
08/16/09 08:06 PM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
The one that perplexes me the most is a fuel problem. The car is a 64 Polara with a fresh 440(420 H/P-510ft/lbs)It has an electric fuel pump which is not usually hooked up and a mech pump.After priming the carb it fires up but won't stay running.Acts like it runs out of gas and no gas pumping into carb. Activated the electric pump and motor runs fine. I figured the mech pump was shot and replaced it with a new one.We primed the carb using the electric pump and fired it up. It will run for about 2 minutes then runs out of fuel and dies. I'm just gonna run the electric pump,but am curious as to why it will run 2-3 minutes on the mech pump.I didn't run it for more than a few seconds with the electric cause I wasn't sure if it was safe to do so useing the mech pump too.I read the electrc/mech fuel pump post so I am a little more informed in that area now. Anyway, any ideas on why it will run 2-3 minutes then die?
This would be so much easier if I knew what I was doing...
Re: New motor in,got a couple of problems
[Re: coro500net]
#440220
08/16/09 08:20 PM
08/16/09 08:20 PM
Deleted prior to arrival of politically biased moderators
#440222
08/16/09 08:30 PM
08/16/09 08:30 PM
RapidRobert
Hookup a can of gas w a neoprene line to the (mech)pump inlet & fire it up. This will cut the problem(area) in half & tell you if the issue is w the mech pump(& pushrod if BB) or rearward(elec pump/tank pickup/hoses.
[Re: RapidRobert]
#440223
08/16/09 08:36 PM
08/16/09 08:36 PM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
yup, turning the electric pump off doesnt eliminate it from your system.
[Re: Baxter61]
#440225
08/16/09 08:47 PM
08/16/09 08:47 PM
Polarabill
N.E.Ohio
Thanks to all for the imput. I'll start troubleshooting tomorrow and see what I find.
