Heavier pistons, balancing question..
#440210
08/16/09 08:02 PM
08/16/09 08:02 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Is there a direct formula/percentage for figuring out how much Mallory Metal will be needed in balancing? In other words say I have a 1000 gram piston,pin,locks,rings assembly that has been accurately balanced to the total rotating assembly...Now I just added 200 grams to the pistons. Is there a formula that can tell me how much Mallory Metal will be needed....no algebra, trig or calculus please. Thanks Curt
Oh yeah...THAT'S gonna leave a mark!
Re: Heavier pistons, balancing question..
[Re: Curt]
#440211
08/16/09 08:48 PM
08/16/09 08:48 PM
RapidRobert
Curt I cannot ans your Q directly but if I could I would guarantee you that my ans would not include any algebra calculus or trig
[Re: HotRodDave]
#440213
08/18/09 08:08 PM
08/18/09 08:08 PM
Curt
JAX FLA
So would the end result be more or less Mallory metal required than piston weight discrepancy? or roughly times two, times 4 ??? Thanks Curt
[Re: Curt]
#440214
08/18/09 08:36 PM
08/18/09 08:36 PM
RapidRobert
The bobweight used to balance may be in the range of 2200 grams and you are changing that by 200 grams by adding to the reciprocating weight a 200 gram heavier piston(2 pistons on each throw but you use 1/2 of the recip weight). No math(I promised).
