Page 36 of 41 1 2 34 35 36 37 38 40 41
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69B3GT] #43950
06/12/09 02:11 PM
06/12/09 02:11 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Man the car is looking great! Keep up to awesome work
I love to see it coming together!
65 Barracuda
70 Challenger
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: jrwoodjoe] #43951
06/12/09 06:31 PM
06/12/09 06:31 PM
san diego
JonsGottaDusta Offline
san diego
You are doing a great job Steve! Keep it up!
- jon
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: JonsGottaDusta] #43952
06/13/09 07:14 PM
06/13/09 07:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Wont be long now
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: WILD BILL] #43953
06/18/09 07:46 AM
06/18/09 07:46 AM
Millersville, PA
HemiChallenger Offline OP
Millersville, PA
Thanks guys! I keep running into some stupid problems and im trying to sort those out! Will get a new update sometime soon!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43954
06/18/09 06:40 PM
06/18/09 06:40 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Every problem you knock down, even those not car related, is just one more obstacle out of your way.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: DynoDave] #43955
06/22/09 01:20 AM
06/22/09 01:20 AM
Millersville, PA
Millersville, PA
Thanks for the support Dave!
So onto problem one. The passenger spindle.
The rotor would not go on the spindle, turns out the diameter is .25" to big which means i needed to find another spindle. So i run out and pull on off of another front suspension, bring it home, same problem. So that means i had no option but to pull one of a suspension that was in a car that burnt to the ground. That was quite the adventure...
Here we finally got the rotor and caliper off with lots of heat, notice the inner part of the bearing is still on the rotor Not moving at all...
whats left of the bearing in the rotor...
So the inner part of the bearing need to be cut off as it was not moving. So our friend very carefully torched it out...
Here is the aftermath, then we also broke all three dust cover bolts, which in turn broke a drill bit and a tap. This was a very interesting project
All done, spindle is cleaned and primed, just needing paint...
Then steering column troubles (knew it was coming, still trying to find an alternative to spending $150 for the flaming river kit...
On the upside, i polished the headlight rings (three backs not done, just to compare)
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43956
06/22/09 03:55 AM
06/22/09 03:55 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
That doesn't look like you were having much fun at all.
As far as the steering goes, the distance in the pic is more than the difference between power and manual steering, so what gives? I wonder if your column "slipped". I had the unit out of my 69 runner a few years ago, and when I went to re-install, the stupid thing had shrunk 3". Needless to say, I figured out that the column had somehow been collapsed a bit being moved around the shop. Brought it out where it needed to be, and problem solved.
Now, assuming that is a PS column, you'd still likely be a bit short. I had HEARD that MS vans had the same adapter factory as FR sells aftermarket. Might be worth a lookand a LOT cheaper.
2 Demons...no, not my kids!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 4speeds4me] #43957
06/22/09 09:48 AM
06/22/09 09:48 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Steve,
I had thought my column was a power column in my manual car and was shopping for a new one. Jules assured me that it was indeed a manual column. I was able to pulled the column shaft up while it was out of the car. Worth a shot.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 1fastrunner] #43958
06/22/09 02:15 PM
06/22/09 02:15 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
That is a power steering shaft and it CANNOT and should NOT be pulled out to reach the manual steering box.
The opposite is okay. Manual compressed to power is fine but not the opposite.
Not enough shaft will be left inside the tube.
Jules
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: JulesdaWiperman] #43959
06/23/09 05:15 PM
06/23/09 05:15 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Someone sells an adapter to take up the distance from PWR to Manual steering. I think Firm Feel makes them. We use one on a friends E-Body to conver to manual steering on his race car. I hope to see that car at Carlisle and keep up the great work.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43960
06/23/09 09:57 PM
06/23/09 09:57 PM
B.C, Canada
69bronzeT5 Offline
69bronzeT5  Offline
B.C, Canada
What kind of car was it? Also, what did you use to polish the headlight rings?
Feature Editor; Mopar Connection Magazine
'69 Charger- T5 Copper- 383 auto
'70 Coronet 500- F8 Green- 318 auto
'71 Charger R/T- B5 Blue- 440 auto
'71 Charger R/T- GY3 Citron Yella- 440 auto
'71 Charger Super Bee- GY3 Citron Yella- U-Code 440 4-spd
'79 Power Wagon- Red- 318 auto 4x4
'06 Grand Cherokee SRT8- Black- 6.1L HEMI auto
'08 Challenger SRT8- Hemi Orange- 6.1L HEMI auto
'12 Ram 3500- True Blue- 6.7L Cummins Auto 4x4
'17 Wrangler Winter Edition- Plum Crazy- 3.6L 6-Speed
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69bronzeT5] #43961
06/27/09 03:06 AM
06/27/09 03:06 AM
Millersville, PA
Millersville, PA
Thanks for the tips guys, after talking with Jules i have it all figured out, ill post what i did later. The spindle was off of a 70 Challenger. I used some polishing compound that i found at lowes, the is levels 1-6 6 being high gloss, and it looks sweet when you get use it
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43962
06/29/09 01:15 AM
06/29/09 01:15 AM
B.C, Canada
69bronzeT5 Offline
69bronzeT5  Offline
B.C, Canada
Hey Steve,
Any chance you have a picture of the car? I'd be really interested in seeing it.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69bronzeT5] #43963
07/12/09 03:48 PM
07/12/09 03:48 PM
Third Stone from the Sun
Scotts72Rallye Offline
Steve,
I saw the Bee Saturday at Carlisle and it looked damn good. Very nice work!
Scott
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: Scotts72Rallye] #43964
07/14/09 05:15 PM
07/14/09 05:15 PM
Millersville, PA
Millersville, PA
69bronzeT5 I'll email you a pic of the car if i can find one, have to go through some old files...
Scotts72Rallye Thanks Scott, a lot of guys seemed to like it, its reassuring that the works been worth it!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69bronzeT5] #43965
07/23/09 02:45 PM
07/23/09 02:45 PM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
we want an update! we want an update!
*1969 383 4sp. Super Bee
*1966 Alfa Romeo Giulia Sprint GT
*1965 Porsche 356C
*2004 VW Passat Wagon
*2004 Mini Cooper S
*1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43966
07/25/09 04:47 AM
07/25/09 04:47 AM
B.C, Canada
69bronzeT5 Offline
69bronzeT5  Offline
B.C, Canada
Thanks Steve!
-Cody
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69bronzeT5] #43967
07/28/09 04:51 PM
07/28/09 04:51 PM
Millersville, PA
Millersville, PA
Alright guys i know its been awhile since i updated but a lot has been going on to prevent me from posting.
The car was at carlisle if anyone was there you would have easily know it was this car but the incompleteness and it being the only motorless car on the showfield. Anyways did see a few of you and it was good to talk to you guys.
In addition to that i lost my camera for about a month so the pictures for about a month are very minimal and only end results...
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43968
07/28/09 04:57 PM
07/28/09 04:57 PM
Millersville, PA
Millersville, PA
I painted the gas tank black different i know but i saw a car with a body color tank and from the rear end it looked good so i went ahead and did that...
Refinished the gauge cluster and put a stock radio in for now until i finish up my radio delete panel. Also installed the steering column. I ended up taking an e-body manual steering shaft that i had here and used that instead of buying a power to manual coupler...
I also picked up a tuff wheel adapter at a local junkyard for $15 as i plan to put a rim blow on the car
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43969
07/28/09 05:07 PM
07/28/09 05:07 PM
Millersville, PA
Millersville, PA
Now for the most exciting thing. I have a friend who helped me out big time with some parts. We did a very large trade deal of parts for these cars. I ended up getting some nice parts and a new option for the car...
So i got a near complete ram charger hood assembly and just need to do some metal work to the hood and i will have a ram charger hood for the car.
In addition to that i picked up some of the cleanest sidemarkers anyones ever seen. Check the how nice the rears are (the back of them is still super glossy and the lenses are perfect[pics do no justice])
Also got a bunch of original spoiler hardware and the mounting brackets for the grilles...
And finally picked up some nice original front upper door panels. At the bottom of the panel in a bag is some of the rubber insulation that goes on wiper motors. I have to thank Jules big time for donating this stuff!
I'll try to get some pics of the car up here soon
