Hmmmm...maybe one of the orange wires used to be red....
As well, I'm going to tie them into the stock Batt and ACC plugs located under the dash
also there are 3 triple plugs under the dash that use the bullet connectors , if I remeber right the yellow plug is constant power , the red plug is switched power & the orange is dash lights , all of these are there specifically to add accories or extra circuits ... too bad stereo installers never figure that out instead of just hacking into the harnesses
