sure grip rear end whines #439209
08/15/09 10:00 PM
08/15/09 10:00 PM
Springfield, IL
dons4406 Offline OP
dons4406  Offline OP
Springfield, IL
I HAVE A 69 CORONET R/T WITH 8 3/4 489 CASTING REAR CENTER SECTION. I HAD THE 3:23 GEAR RELACED WITH A 3:55 RATIO AND NOW IT WHINES FROM ABOUT 45 mph UP. I HAVE HAD SEVERAL OTHERS DONE AND NEVER A PROBLEM. ANY IDEAS WHAT WENT WRONG TO CAUSE IT TO WHINE??? ANY HELP WOULD BE GREATLY APPRECIATED.
THANKING YOU IN ADVANCE.
DON
Re: sure grip rear end whines [Re: dons4406] #439210
08/15/09 10:20 PM
08/15/09 10:20 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
What brand of gearset? Richmonds are notorious for being noisy, but it's also possible that the setup is'nt perfect.
Re: sure grip rear end whines [Re: dons4406] #439211
08/15/09 11:40 PM
08/15/09 11:40 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Did you check all gear surfaces including the spider gears for pitting?
Re: sure grip rear end whines [Re: dons4406] #439212
08/16/09 12:10 AM
08/16/09 12:10 AM
If these 3.55's were a new gear set they set them up wrong.
