second time for metal flakes in the gear lube... why? #439149
08/15/09 08:32 PM
08/15/09 08:32 PM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
About two years back, the clutch packs became damaged and ended up leaving a ton of metal flakes in the gear lube (8 3/4, 742 carrier, locker). Initially, I had a shop set up the rear end and after it happened, I went to a different place to get it fixed. Back then, it had lasted a year, almost to the date. The car had only a dozen passes (67 Coronet, 470, 727, 3.91, MT radials) and I can't believe they have gone bad AGAIN.
The first shop I had it done at was probably not the best route to go, but as far as where I got it 'fixed', they DEFINITELY knew what they were doing. It has been a year AGAIN, almost to the date, and again about a dozen passes this year. I once again have metal flake in the gear lube and I'll bet a brand new Ben Franklin I know what it is.
Soooo... the question is this. I do not want this to happen again so what can be done to prevent it? Is there a way to 'beef' it up or install 'stronger' parts? I have no idea how to repair these and will have to take it to a different shop to get it fixed.
I thank you for your input. Dave
Re: second time for metal flakes in the gear lube... why? [Re: 67dodge67] #439150
08/15/09 08:43 PM
08/15/09 08:43 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
You say a TON of flakes ? ... could be the bearings coming apart. Have you got a little donut magnet to put in there?
Re: second time for metal flakes in the gear lube... why? [Re: dOoC] #439151
08/15/09 08:49 PM
08/15/09 08:49 PM
WI, USA
mopar addict
mopar addict
WI, USA
forgot to include this, the green bearings are new and were packed/installed correctly. thanks.
Re: second time for metal flakes in the gear lube... why? [Re: 67dodge67] #439152
08/15/09 09:24 PM
08/15/09 09:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
running the mopar friction modifier?
Re: second time for metal flakes in the gear lube... why? [Re: 67dodge67] #439153
08/15/09 10:03 PM
08/15/09 10:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not put a spool in it
Re: second time for metal flakes in the gear lube... why? [Re: J_BODY] #439154
08/15/09 10:24 PM
08/15/09 10:24 PM
WI, USA
mopar addict
mopar addict
WI, USA
I did add a friction modifier, but not the mopar one. Does that make a difference? The name of it is Trans-X posi-trac limited slip gear oil additive. Sorry, but I'm new to this.
Thanks for your help. Dave
Re: second time for metal flakes in the gear lube... why? [Re: MR_P_BODY] #439155
08/15/09 10:27 PM
08/15/09 10:27 PM
WI, USA
mopar addict
mopar addict
WI, USA
The car sees MAYBE a dozen trips to the strip in a year. It's basically a street car. From what I understand, a spool is not good for the street. Am I wrong?
Thanks for your reply. Dave
Re: second time for metal flakes in the gear lube... why? [Re: 67dodge67] #439156
08/15/09 10:37 PM
08/15/09 10:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I drove one on the street for a FEW years... cant take
corners quick other than that it was fine
Re: second time for metal flakes in the gear lube... why? [Re: MR_P_BODY] #439157
08/15/09 11:53 PM
08/15/09 11:53 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Just wondered... Guess that's the only thing that came to mind as it sounds like you wiped out the clutches for the sure grip and not the pinion or side bearings. Did the rear ever feel "grabby" when making slow sharp turns? (parking lot manuevers)
Re: second time for metal flakes in the gear lube... why? [Re: J_BODY] #439158
08/16/09 12:13 AM
08/16/09 12:13 AM
WI, USA
mopar addict
mopar addict
WI, USA
It DEFINITELY does. When I make a sharp turn, like out of a gas station, I can tell it seems to 'grab' or 'bind up' and lose power. I also have heard a LOUD 'snap' when making a VERY sharp turn, but only after it has started up and I pull it out of my storage garage or the gas station which is just around the corner (2 minute drive). After it warms up, it goes away.
I have heard a VERY loud 'bang' which sounded as if the rear brakes were 'stuck' together and then seperated, as if they 'popped' open; as if they were rusted together due to sitting after a year or two.... or the emergency brake was stuck and it then popped free. That's the sound it makes....
Thanks.
Re: second time for metal flakes in the gear lube... why? [Re: 67dodge67] #439159
08/16/09 12:37 AM
08/16/09 12:37 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well that's how a sure grip feels when there isn't any friction modifier. Not sure about the "trans X" or those off the shelf gear lubes that tout that they already have friction modifier in them..... I always ran the mopar additive back in my street days with the 8.75. If it was binding up that bad at least you know what it would feel like to drive with a spool.
Re: second time for metal flakes in the gear lube... why? [Re: J_BODY] #439160
08/16/09 01:22 AM
08/16/09 01:22 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There could also be issues with the parts used to rebuild the unit, there are some out there that are known for problems, I would strongly suggest contacting Dr Diff... He knows the Mopar stuff far better than most...
Re: second time for metal flakes in the gear lube... why? [Re: 1_WILD_RT] #439161
08/16/09 06:33 AM
08/16/09 06:33 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Bet your clutches are too thick, get the proper mopar clutches and you'll be fine.
Re: second time for metal flakes in the gear lube... why? [Re: CokeBottleKid] #439162
08/16/09 10:17 AM
08/16/09 10:17 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Do you happen to know if the place reversed any of the plates? That was an old trick to really tighten up a Sure-Grip.
Re: second time for metal flakes in the gear lube... why? [Re: Leigh] #439163
08/16/09 02:24 PM
08/16/09 02:24 PM
WI, USA
mopar addict
mopar addict
WI, USA
Got in touch with someone today who is close by and he will be looking at it next weekend. Thanks for all of the input here, I do appreciate it.
