How long does it take for Red loctite to dry? #439069
08/15/09 05:59 PM
08/15/09 05:59 PM
Anonymous OP
Anonymous OP
i just found all my torque converter bolts loose and i just used red loctite and tightened them back up.what the time frame for 100% cure and dry time.
i want them to be completely dry so they dont come loose. i might have started the car up prematurely the 1st time.
Re: How long does it take for Red loctite to dry? #439070
08/15/09 06:02 PM
08/15/09 06:02 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i was wondering the same thing. 24 hours at room temp should be enough. but heat would definitely speed it up. if its tight, starting it up and getting the converter hot shouldnt hurt it.
Re: How long does it take for Red loctite to dry? [Re: aarcuda] #439071
08/15/09 06:04 PM
08/15/09 06:04 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Re: How long does it take for Red loctite to dry? [Re: aarcuda] #439072
08/15/09 06:44 PM
08/15/09 06:44 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
If the bolts are nice and snug ... I would not have a prob with firing-it right up.
I have done it before.
Re: How long does it take for Red loctite to dry? [Re: dOoC] #439073
08/15/09 08:13 PM
08/15/09 08:13 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The friction & heat from torquing the bolt usually cures Red loctite almost immediately.
Re: How long does it take for Red loctite to dry? [Re: RyanJ] #439074
08/15/09 08:22 PM
08/15/09 08:22 PM
Anonymous OP
Anonymous OP
i put 1 bolt in hand tight
with the loctite just to see after 2 hours if if would come out, yes it came right out and loctite was still wet and sticky. these are new bolts.
Re: How long does it take for Red loctite to dry? #439075
08/15/09 08:28 PM
08/15/09 08:28 PM
Florida STAYcation
Florida STAYcation
If they are brand-new bolts .. there could have been a film of oil on them. It is BEST to clean-em with brake-clean before using.
Re: How long does it take for Red loctite to dry? #439076
08/15/09 08:29 PM
08/15/09 08:29 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
"hand tight" You must TQ it to stretch the bolt & produce the friction between the threads that the loctite uses to cure.....Yes it will not cure without the heat from friction.
Re: How long does it take for Red loctite to dry? [Re: RyanJ] #439077
08/15/09 08:42 PM
08/15/09 08:42 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Does it not also rely on the abscense of air as a catalyst to cure?
Re: How long does it take for Red loctite to dry? [Re: RyanJ] #439078
08/15/09 10:41 PM
08/15/09 10:41 PM
Anonymous OP
Anonymous OP
technically, it has nothing to do with the heat and friction of tightening the bolt. Loctite is an anaerobic sealer. much like plain old superglue. you must remove any air for it to harden. a loose bolt doesen't do that. a tight bolt does. heat will soften the loctite after it's cured. how much heat depends on the grade of loctite used.
Re: How long does it take for Red loctite to dry? #439079
08/16/09 09:21 AM
08/16/09 09:21 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It ready to be used as soon as you torque the fastner. It doesn't have to dry.
Re: How long does it take for Red loctite to dry? [Re: Challenger 1] #439080
08/16/09 11:47 AM
08/16/09 11:47 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What about wet torque vs dry, oil and loc tite? , do ya clean your bolts and loc tite them or oil them and wet torque them, any body using loc tite on rod bolts? Let the games begin
Re: How long does it take for Red loctite to dry? [Re: emarine01] #439081
08/16/09 12:07 PM
08/16/09 12:07 PM
Cincinnati, Ohio
Cincinnati, Ohio
NO! and hell no!
Re: How long does it take for Red loctite to dry? [Re: Challenger 1] #439082
08/16/09 01:24 PM
08/16/09 01:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Well that was clear cut Nobody has ever wet torqued a rod bolt , cleaned the last thread and put a drop of loc tite on for the hell of it
Re: How long does it take for Red loctite to dry? [Re: emarine01] #439083
08/16/09 02:19 PM
08/16/09 02:19 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I use assembly lube and a stretch gauge
It's the only accurate way to tell for sure how much tension is actually in the bolt shank. Otherwise your torque reading could be overcoming friction in the threads and face of the nut and not clamping the cap!
-Charles
ps no Loctite either
