pressure drop in trans #438652
08/15/09 07:40 AM
08/15/09 07:40 AM
btomasko Offline OP
btomasko  Offline OP
a 1969 roadrunner 727 automatic. When this car warms up it shifts and holds the pressure fine but when it gets hot or norman operating temp the pressure drops considerably there by causing a non shift into high, any solutions? thanks
Re: pressure drop in trans [Re: btomasko] #438653
08/15/09 04:40 PM
08/15/09 04:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Where are you measuring the pressure?
Re: pressure drop in trans [Re: John_Kunkel] #438654
08/15/09 05:01 PM
08/15/09 05:01 PM
btomasko Offline OP
btomasko  Offline OP
John, on the side where the adjustment is made. thanks
Re: pressure drop in trans [Re: btomasko] #438655
08/16/09 10:40 AM
08/16/09 10:40 AM
btomasko Offline OP
btomasko  Offline OP
BTT
Re: pressure drop in trans [Re: btomasko] #438656
08/16/09 05:04 PM
08/16/09 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Do you mean the governor test port in the tail housing? If so I would suspect worn governor sealing rings.
