Oil pan contents and levels #438414
08/15/09 12:05 AM
08/15/09 12:05 AM
Cab_Burge Online work OP
Cab_Burge  Online Work OP
I decided to check the oil level in my Charleis oil pan, which I bought off of a member on here and I didn't have a part number to work with to ask Charlie on how much it should hold. He did say that most of his oil pans like this one, aluminmum SS style with a kick out and a tube for the steering cross bar, usually held 8 to 10 quarts depanding on the car and depth of the sump. I will post the first picture on here, the amount of oil is written on the rear of the pan above the rear oil pan slosh baffle on the end of the oil pan 8 quarts if I remember correctly
Re: Oil pan contents and levels [Re: Cab_Burge] #438415
08/15/09 12:08 AM
08/15/09 12:08 AM
This one si with 10 quarts, which puts the oil level even with the front and rear slosh baffles BTW 4 quarts barely covers the Milidon swinging pick up which would be a quick way to burn up some bearings under acceleration or deacceleration if you ran it that way
Re: Oil pan contents and levels [Re: Cab_Burge] #438416
08/15/09 12:11 AM
08/15/09 12:11 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So you didn't think that 8 qt. might have been a clue?
Re: Oil pan contents and levels [Re: Cab_Burge] #438417
08/15/09 12:14 AM
08/15/09 12:14 AM
Last one at 12 quarts, a good way to flood the rear main seal under acceleration. the oil level is above both oil slosh baffles, front and rear I will probally run 9 quarts in this pan the first time I run it at the track, I did run it with 12 quarts on the engine dyno because I was afraid of running it out of oil due to the Indy head oiling issue we had with another motor I help on before running this one. The other motor does not have a crankshaft scraper or windage tray , my motor has both. I have since restricted the oil to the rocker arms on this motor and the other one
Re: Oil pan contents and levels [Re: Cab_Burge] #438418
08/15/09 12:15 AM
08/15/09 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I decided to check the oil level in my Charleis oil pan, which I bought off of a member on here and I didn't have a part number to work woith to ask Charlie on how much it should have. He did say that most of his oil pans like this one, aluminmum SS style with a kick out and a tube for the steering cross bar, usually hold 8 to 10 quarts depanding on the car and depth of the sump. I will post the first picture on here, the amount of oil is written on the rear of the pan above the rear oil pan slosh baffle on the end of the oil pan 8 quarts if I remember correctly
I always use the cubic inches to figure the volume
when I make pans(231 cu in per gal) then when completed
fill them to check
Re: Oil pan contents and levels [Re: MR_P_BODY] #438419
08/15/09 12:18 AM
08/15/09 12:18 AM
Raff, some of us old high school drop outs didn't get them formula in high school auto class, let alone remember them Mike, thanks for the help., I will write that one down in my auto math handbook Now, if I can just figure out how to figure C.I in a triangle
Re: Oil pan contents and levels [Re: Cab_Burge] #438420
08/15/09 12:27 AM
08/15/09 12:27 AM
rowin4 Offline
rowin4  Offline
Cab, now I se what you were doing, I first thought that you didn't know how much to put it the pan when the 8 qts. was written on the back. I've did the same filling thing to see were the added qts. came up to.
Re: Oil pan contents and levels [Re: Cab_Burge] #438421
08/15/09 12:27 AM
08/15/09 12:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Raff, some of us old high school drop outs didn't get them formula is auto class, let alone remember them Mike, thanks for the help., I will write that one down in my auto math handbook
LOL... that all I remember is the numbers... I cant
even remember my name(thanks for reminding me...LOL)
Re: Oil pan contents and levels [Re: MR_P_BODY] #438422
08/15/09 07:06 AM
08/15/09 07:06 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Great post....
I usually run 9-10 qts in mine...........nice to see how much is sitting in the pan in your pics,,,thanks,
Re: Oil pan contents and levels [Re: 69CHARGERMD] #438423
08/15/09 07:10 AM
08/15/09 07:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug it looks funny to see a doc working on cars...
you need the white lab coat.... LOL
Re: Oil pan contents and levels [Re: MR_P_BODY] #438424
08/15/09 07:24 AM
08/15/09 07:24 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Mike,,,,how's this...... ...( gettin better at the photoshop thing,,lol)
Re: Oil pan contents and levels [Re: 69CHARGERMD] #438425
08/15/09 07:35 AM
08/15/09 07:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL...... better
Re: Oil pan contents and levels [Re: Cab_Burge] #438426
08/15/09 11:06 AM
08/15/09 11:06 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Time to start measuring in gallons...
I think that thing could use a slosh shield between the CL tube and rear of the pan, then you could run more oil.
Re: Oil pan contents and levels [Re: @#$%&*!] #438427
08/15/09 09:13 PM
08/15/09 09:13 PM
It has one, all 3 of the Charlie oil pans I own have them. I don't really want to run any more oil, just enough to serve the motors needs
Re: Oil pan contents and levels [Re: Cab_Burge] #438428
08/16/09 09:30 PM
08/16/09 09:30 PM
WA 98043
thecarfarmer Offline
WA 98043
I was going to post this up last night at work, but realized I didn't have any pics of my pan on the shop computer.
I put lexan (a little better heat resistance than acrylic) windows in the front and side at the RF corner of the pan, sealed w/ grey silicone and secured with 1/4-20 bolts (double-nutted).
I'd thought that I couldn't use a disptick, because there's no 'bump' to clear it in the side of the pan. But, it sneaks down past it anyway...
FWIW, this is a Charlie's dragster pan w/ a trap door halfway back, baffles front % rear, and a swinging pickup. I'm also running a Milodon swinging pickup.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Oil pan contents and levels [Re: thecarfarmer] #438429
08/16/09 09:32 PM
08/16/09 09:32 PM
WA 98043
WA 98043
...in situ...
-Bill
