Clutch Eye Candy #437707
08/14/09 12:07 PM
08/14/09 12:07 PM
SC
Greg Offline OP
Greg  Offline OP
SC
I just got my new clutch in and figured all you stick guys would appreciate the unit. I am getting closer to getting the car out. My plan is to atleast make some shake down passes this year.
Re: Clutch Eye Candy [Re: Greg] #437708
08/14/09 12:09 PM
08/14/09 12:09 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I hear their clutches are awesome.Expensive but good.Rocky
Chrysler Firepower
Re: Clutch Eye Candy [Re: therocks] #437709
08/14/09 12:48 PM
08/14/09 12:48 PM
SC
Greg Offline OP
Greg  Offline OP
SC
If you are looking for a heavy duty steet/race unit they are very competitively priced. I use street very very loosely because most people who run on the street would see this as overkill unless you were serious about not junking parts on a high horsepower street/strip car.
I looked at Advance, Tim Hyatt and McCloud. All of them make some nice clutches. My engine builder has used McCloud forever. Boninfante was not the highest priced supplier out there.
I talked to a lot of guys racing 4 speeds with bigger cars and and the guys who were running Boninfante said they were very happy with the durability of the unit. The guys at Texas Thunder have had a lot of success running the Boninfante unit and Mike Loboda uses one in his pro stock duster. I am not going class racing so every little tenth is not a big concern for me. My deciding factor was durability and adjustibility.
When the president of the company gives you his personal cell phone number and says call me anytime you need anything. That to me tells you about the way he feels about customer service.
Re: Clutch Eye Candy [Re: Greg] #437710
08/14/09 01:04 PM
08/14/09 01:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yeah my Buddy at Texas Thunder has it in the 65 Coronet.He launches with what 14 inch slicks.Rocky
Chrysler Firepower
Re: Clutch Eye Candy [Re: therocks] #437711
08/14/09 01:39 PM
08/14/09 01:39 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
That is soo cool......I don't even know what I'm looking at!
I guess its an adjustible multi disc unit.
What kind of Discs?
What kind of HP is it going behind
What kind of Trans?
I guess this clutch is designed to "slip" at launch.
Re: Clutch Eye Candy [Re: LAR_414] #437712
08/14/09 02:32 PM
08/14/09 02:32 PM
SC
Greg Offline OP
Greg  Offline OP
SC
Horsepower - 690-710
6 lever 10' single disk clutch
Jerico Transmission
Long V Gate Shifter
Lakewood Bellhousing
Brewer's Performance clutch fork and sundry items
1964 Plymouth Sport Fury
Ohio Crankshaft 500 Stroker Kit
Indy SR Max wedge port
Indy Intake
2-800 CFM Carbs from Diamondback Engines
Stock Block
TTI 2-2 1/8 Step Headers
Bob's Pro Fab lightened K Member
Afco double adjustable front shocks
Caltracs Mono Leaf springs & bars
Dana 60
Strange 4.56 Pro gear set
Strange 35 Spline axles - Bob's Pro Fab
Mickey Thompson 29.5 X10.5W X 15 tires
Still working on other items
Re: Clutch Eye Candy [Re: Greg] #437713
08/14/09 03:26 PM
08/14/09 03:26 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
So are you saying that this clutch is somewhat streetable?
Re: Clutch Eye Candy [Re: 446acuda] #437714
08/14/09 03:44 PM
08/14/09 03:44 PM
LAR_414 Offline
LAR_414  Offline
What is the disc material? Is it supposed to slip?
I've got a RST Mcloud dual 9.75ish" disks with organic face. Super streetable and doesn't slip a bit. I will rely on a bit of tire spin to keep from bogging / breaking.
Re: Clutch Eye Candy [Re: Greg] #437715
08/14/09 03:54 PM
08/14/09 03:54 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Nice unit Greg
Can you upgrade to a dual disc setup with just new stands and a floater when you need to? I didn't think that unit would fit in a standard bell.
Gus
64 Plymouth Savoy
Dana 60
Re: Clutch Eye Candy [Re: fourgearsavoy] #437716
08/14/09 04:29 PM
08/14/09 04:29 PM
SC
Greg Offline OP
Greg  Offline OP
SC
It is a six finger single disk slipper style clutch. It has a 130 tooth flywheel and will fit into a Lakewood bellhousing. The ad below says it would fit into a stock style housing. Personally if you are making that much horsepower I would want an SFI approved bellhousing anyway. It can be expanded to a dual disk clutch. $1950.00 out the door and into your car. Here is an ad for the clutch. Sorry it is in chevy Max online magazine.
Boninfante Clutch Ad
Re: Clutch Eye Candy [Re: Greg] #437717
08/14/09 05:04 PM
08/14/09 05:04 PM
Rittman Ohio
Rittman Ohio
I just thought you might have to get a Browell or Trick Titainium to fit that size hat inside.Did you see the new proposed window design that Tim Hyatt submitted to Lakewood? It is posted over on www.umtrnorth.com in the tech section.It will make adjustments and weight changes alot easier
Gus
64 Plymouth Savoy
Dana 60
Re: Clutch Eye Candy [Re: fourgearsavoy] #437718
08/14/09 05:50 PM
08/14/09 05:50 PM
SC
Greg Offline OP
Greg  Offline OP
SC
I saw Tim Hyatt's thread on the bellhousing window. It is really needed and the bellhousing still would be safe.
Re: Clutch Eye Candy [Re: Greg] #437719
08/14/09 06:28 PM
08/14/09 06:28 PM
Rittman Ohio
Rittman Ohio
Yeah when you look at the size of the hole where the fork comes through why cant you put a safer one somewhere else
Gus
64 Plymouth Savoy
Dana 60
Re: Clutch Eye Candy [Re: fourgearsavoy] #437720
08/14/09 09:21 PM
08/14/09 09:21 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Greg, you're gonna love that Boninfante unit.
He makes a great product and you'll NEVER break it- believe me, I've tried !
http://www.youtube.com/watch?v=m13VbDl0JwA
Re: Clutch Eye Candy [Re: mloboda] #437721
08/14/09 09:43 PM
08/14/09 09:43 PM
Somewhere Over the Hill
Mr. Dodge Offline
Mr. Dodge  Offline
D A M N!!!!!!!!!!!!!!!!!!!
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
Re: Clutch Eye Candy [Re: mloboda] #437722
08/14/09 09:44 PM
08/14/09 09:44 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Thats sweet Greg
Re: Clutch Eye Candy [Re: 340RICK] #437723
08/14/09 11:25 PM
08/14/09 11:25 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dave in Texas is runnign that with a Jerico behind a 572,He has never had a clutch problem.Rocky
Chrysler Firepower
Re: Clutch Eye Candy [Re: therocks] #437724
08/14/09 11:32 PM
08/14/09 11:32 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Ok, without going into great detail, why would you spend that kind of money for a clutch set up for a street car? a good performance clutch would last for years. Besides no one can see the bling anyways.
Re: Clutch Eye Candy [Re: rowin4] #437725
08/15/09 09:29 AM
08/15/09 09:29 AM
Rittman Ohio
Rittman Ohio
It's the perfect clutch for street/strip big HP cars because you can tighten it up for the street and back the pressure down at the track On the street traction is limited and tire spin is the "slip factor" when on the track traction is good so you need to put the slip in the driveline so you back off your adjustment a few thousand pounds.
Gus
64 Plymouth Savoy
Dana 60
Re: Clutch Eye Candy [Re: LAR_414] #437726
08/15/09 12:45 PM
08/15/09 12:45 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i'm thinking about trying the rst clutch. can you use any flywheel,or do you need a special one? what do you use?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
