Edelbrock 800 CFM Recalibration ???? #437642
08/14/09 10:09 AM
08/14/09 10:09 AM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Ive got a stock Edelbrock Performer series 800 CFM carb, I would like to richen it up, I ordered the #1480 kit and would like to know which needles, springs and metering jets to go with, any help would be greatly appreciated.
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: Edelbrock 800 CFM Recalibration ???? [Re: 1AARCUDA] #437643
08/14/09 10:59 AM
08/14/09 10:59 AM
use a pair of springs w a vac rating 1/2 of what your idle vac is in drive. look up the # on your current rods for the dia of the "cruise" step and the "power" step or use a micrometer & select a rod the next size thinner on whichever one of those areas you want to richen. I'd leave the jets as is for now & see if you can fine tune w the rods 1st. a person really needs a wide band A/F meter to get this spot on otherwise your pretty much guessing other than what your seat of the pants driveability tells you.
