am i gonna run out of gear on the 1/4 mile? #437533
08/14/09 08:27 AM
08/14/09 08:27 AM
montreal, quebec, canada
jimmy71demon Offline OP
my 416 build is gonna be ready within the next few weeks. i have a 727 stall 3 speed tranny (shift kit) with a stall of 3500 rpm. and the back end is 3.91 richmond gearing. that was pretty much just enough when the engine was a 340 0.040 oversized. so im thinkin that now with more power and torque im gonna be shifting sooner. am i gonna have to change the gearing to 3.73?
thanks for ur input!
Im goin fast Mom!
Re: am i gonna run out of gear on the 1/4 mile? [Re: jimmy71demon] #437534
08/14/09 08:30 AM
08/14/09 08:30 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think the 3.91's will be fine.
Coming soon!!!!
Re: am i gonna run out of gear on the 1/4 mile? [Re: Mr.Yuck] #437535
08/14/09 08:51 AM
08/14/09 08:51 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Your shift points may go higher rather than lower with the new set up.You will have to play around until you find the sweet spot again.
Re: am i gonna run out of gear on the 1/4 mile? [Re: stumpy] #437536
08/14/09 09:15 AM
08/14/09 09:15 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well tire size makes a huge difference what will you be running??
6500 with 26 inch tire will be 118 out the end
6500 with 28 inch tire will be 127 out the end
6500 with 32 inch tire will be 145 out the end
Re: am i gonna run out of gear on the 1/4 mile? [Re: Dodgem] #437537
08/14/09 09:57 AM
08/14/09 09:57 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
With a 3.91 and even a short 26 inch tire it won't make it to 6500 at the stripe.
You won't run out of engine with a 3.91.
Re: am i gonna run out of gear on the 1/4 mile? [Re: MoparforLife] #437538
08/14/09 11:44 AM
08/14/09 11:44 AM
am i gonna want to run it to 6500 rpm? i was thinking 6000 to be safe...
Im goin fast Mom!
Re: am i gonna run out of gear on the 1/4 mile? [Re: jimmy71demon] #437539
08/14/09 01:57 PM
08/14/09 01:57 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
6500 is "safe"...As long as properly built
Re: am i gonna run out of gear on the 1/4 mile? [Re: jimmy71demon] #437540
08/14/09 01:57 PM
08/14/09 01:57 PM
My '70 duster with the 416 in it ran 11.0's at 120 mph with a 3.91 gear...i think you'll be fine
Re: am i gonna run out of gear on the 1/4 mile? #437541
08/14/09 02:00 PM
08/14/09 02:00 PM
Wisconsin USA
Wisconsin USA
Spin it 'till it stops making power...
