Re: another HHR fan question A Bodies ONLY
[Re: gtx69]
#437017
08/14/09 04:02 PM
08/14/09 04:02 PM
gtx69
super gas
super gas
one more I have about 1/4 inch space between fan and pump 80 amp alternator 60 amp at idle
[Re: TheOtherDodge]
#437019
08/14/09 05:04 PM
08/14/09 05:04 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
I would like to know the amp draw also because I don't notice a big drain on the battery, but I also have a fairly big amp alt stock from the factory.
I think my factory alt is about 37 amps peak, so 30+ amps on startup would create problems for me. the fan i bought draws 7.5 max
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: DartMan380]
#437021
08/14/09 11:38 PM
08/14/09 11:38 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
How thick is your radiator? and are you using a front plate... that brings my water pump snout another 3/8" farther forwards thanks Charles
[Re: B3422W5]
#437022
08/14/09 11:59 PM
08/14/09 11:59 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
30+ Amps on Startup??
The poster said About 30 Amps on startup, meaning Less. So with your 37 amp peak alt., You would have more then enough power to run the mizer/Hiflow HHR fan. mike
[Re: DrCharles]
#437023
08/15/09 12:38 AM
08/15/09 12:38 AM
Posts: 356 Akron Ohio
DartMan380
Akron Ohio
Its the summit 26in Rad. I want to say its 2 1/2" thick but not sure and cant measure at this moment.
As close as ours is I dont know if it will clear with a plate. But I do believe ProSport is running one but that is with a big block.
The HHR fan has small cooling fins on the back of the motor that could be shaved off and that would give it a little bit more.
[Re: 69CHARGERMD]
#437026
08/15/09 08:54 AM
08/15/09 08:54 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
"What is that out of",,,, ?? the fan ?, pump ?,,, this is a HHR fan,,in my 65 plymouth,( not a A body,,just saw the title , )with a Meizere pump ( i listed the specs on the pump below ) very pleased with the set up,,,lots of clearance,,and the car runs nice and cool.... Doug Water Pump, Electric, 100 Series, 40 gpm, Billet Aluminum, Black Anodized, Mopar, Big Block, Each Part Number: MEZ-WP105SHD
[Re: 69CHARGERMD]
#437027
08/15/09 10:34 AM
08/15/09 10:34 AM
DrCharles
West Plains, MO
Is the Meziere water pump shorter than the mechanical pump? There does seem to be plenty of room in B-bodies and other, it's only the A-bodies that need every last 1/4 inch -Charles
[Re: Sport440]
#437028
08/15/09 10:44 AM
08/15/09 10:44 AM
B3422W5
Portage,michigan
I have an electric water pump, msd, electric fan,fuel pump, starter, etc, it definately wouldnt work for me. And understand that a 37 amp(max) output alternator isnt putting out that much juice constantly, i dont think, that is just peak. Like i said earlier, a guy on here has a 50 amp denso and had to take the HHR fan off because his charging system couldnt support it. that was enough to sway me, as i dont have nearly as much alternator as he did, and even he had problems.
[Re: B3422W5]
#437029
08/15/09 10:53 AM
08/15/09 10:53 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
If your battery can't handle starting the fan I don't think you'd ever get your engine started.
Thanks for the tread, it reminded me I want to buy one for my '68 Barracuda
[Re: His and Her 69's]
#437030
08/15/09 12:08 PM
08/15/09 12:08 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I have the fan on the front side of my radiator and it is a pusher now. It works Great and fit in the space with only little mods done. This is on a B body though.
Ok this was posted a couple days ago, I PMed him to as if reversing the polarity reversed rotation, I haven't gotten a response back so could someone else with one of these fans tell me if reversing the leads reverses the fan rotation? Thanks!!
[Re: gtx69]
#437035
08/15/09 09:41 PM
08/15/09 09:41 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Am I the only one who mounted my rad in front of the core support?
BB, TT5,Procharged 3300lb Street Car 4.79/154
