Page 2 of 5 1 2 3 4 5
Re: another HHR fan question A Bodies ONLY [Re: gtx69] #437016
08/14/09 03:58 PM
08/14/09 03:58 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Here is a picture of the fan on a 69 gtx
Re: another HHR fan question A Bodies ONLY [Re: gtx69] #437017
08/14/09 04:02 PM
08/14/09 04:02 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
one more I have about 1/4 inch space between fan and pump 80 amp alternator 60 amp at idle
Re: another HHR fan question A Bodies ONLY [Re: RonP] #437018
08/14/09 05:01 PM
08/14/09 05:01 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I would like to know the amp draw also because I don't notice a big drain on the battery, but I also have a fairly big amp alt stock from the factory.
Re: another HHR fan question A Bodies ONLY [Re: TheOtherDodge] #437019
08/14/09 05:04 PM
08/14/09 05:04 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I think my factory alt is about 37 amps peak, so 30+ amps on startup would create problems for me. the fan i bought draws 7.5 max
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: another HHR fan question A Bodies ONLY [Re: B3422W5] #437020
08/14/09 11:19 PM
08/14/09 11:19 PM
Akron Ohio
DartMan380 Offline
DartMan380  Offline
Akron Ohio
No pictures but this fan is by far the best I have ever seen. I have looked at about every OEM style fan out there. We had to cut the lip off the rad support to move the rad a 1/4" forward so the fan would clear the snout on the mech water pump.
Re: another HHR fan question A Bodies ONLY [Re: DartMan380] #437021
08/14/09 11:38 PM
08/14/09 11:38 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
How thick is your radiator? and are you using a front plate... that brings my water pump snout another 3/8" farther forwards
thanks
Charles
Re: another HHR fan question A Bodies ONLY [Re: B3422W5] #437022
08/14/09 11:59 PM
08/14/09 11:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
30+ Amps on Startup??
The poster said About 30 Amps on startup, meaning Less. So with your 37 amp peak alt., You would have more then enough power to run the mizer/Hiflow HHR fan. mike
Re: another HHR fan question A Bodies ONLY [Re: DrCharles] #437023
08/15/09 12:38 AM
08/15/09 12:38 AM
Akron Ohio
DartMan380 Offline
DartMan380  Offline
Akron Ohio
thanks
Charles
Its the summit 26in Rad. I want to say its 2 1/2" thick but not sure and cant measure at this moment.
As close as ours is I dont know if it will clear with a plate. But I do believe ProSport is running one but that is with a big block.
The HHR fan has small cooling fins on the back of the motor that could be shaved off and that would give it a little bit more.
Re: another HHR fan question A Bodies ONLY [Re: DartMan380] #437024
08/15/09 06:59 AM
08/15/09 06:59 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: another HHR fan question A Bodies ONLY [Re: 69CHARGERMD] #437025
08/15/09 08:18 AM
08/15/09 08:18 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
what is that out of.... what gpm pump is that....
Mopar Performance
Re: another HHR fan question A Bodies ONLY [Re: 69CHARGERMD] #437026
08/15/09 08:54 AM
08/15/09 08:54 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
"What is that out of",,,, ??
the fan ?, pump ?,,,
this is a HHR fan,,in my 65 plymouth,( not a A body,,just saw the title , )with a Meizere pump ( i listed the specs on the pump below )
very pleased with the set up,,,lots of clearance,,and the car runs nice and cool....
Doug
Water Pump, Electric, 100 Series, 40 gpm, Billet Aluminum, Black Anodized, Mopar, Big Block, Each
Part Number: MEZ-WP105SHD
Re: another HHR fan question A Bodies ONLY [Re: 69CHARGERMD] #437027
08/15/09 10:34 AM
08/15/09 10:34 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Is the Meziere water pump shorter than the mechanical pump?
There does seem to be plenty of room in B-bodies and other, it's only the A-bodies that need every last 1/4 inch
-Charles
Re: another HHR fan question A Bodies ONLY [Re: Sport440] #437028
08/15/09 10:44 AM
08/15/09 10:44 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have an electric water pump, msd, electric fan,fuel pump, starter, etc, it definately wouldnt work for me. And understand that a 37 amp(max) output alternator isnt putting out that much juice constantly, i dont think, that is just peak.
Like i said earlier, a guy on here has a 50 amp denso and had to take the HHR fan off because his charging system couldnt support it. that was enough to sway me, as i dont have nearly as much alternator as he did, and even he had problems.
1.41 best 60 foot
6.56 at 104.17
Re: another HHR fan question A Bodies ONLY [Re: B3422W5] #437029
08/15/09 10:53 AM
08/15/09 10:53 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
If your battery can't handle starting the fan I don't think you'd ever get your engine started.
Thanks for the tread, it reminded me I want to buy one for my '68 Barracuda
Re: another HHR fan question A Bodies ONLY [Re: His and Her 69's] #437030
08/15/09 12:08 PM
08/15/09 12:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I have the fan on the front side of my radiator and it is a pusher now.
It works Great and fit in the space with only little mods done.
This is on a B body though.
Ok this was posted a couple days ago, I PMed him to as if reversing the polarity reversed rotation, I haven't gotten a response back so could someone else with one of these fans tell me if reversing the leads reverses the fan rotation? Thanks!!
Re: another HHR fan question A Bodies ONLY [Re: DrCharles] #437031
08/15/09 12:34 PM
08/15/09 12:34 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I know this post is about the hhr fan. But here is a pick of my big block abody. i am useing a 27.5x19 inch 2 core summit rad. a summit/cvr electric water pump and a fan that was made for a 98 ford turs(spelling). which for my car worked better than the hhr because the one i am useing the motor is off set.I could of made the hhr fan work on my car. but for me it was easer to use the ford one. sorry not trying to high jack the post just letting you guys know there might be a nother opption out there. all so my car temp has not gotton over 180 degrees yet on to back to back passes. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: another HHR fan question A Bodies ONLY [Re: mopar65] #437032
08/15/09 12:37 PM
08/15/09 12:37 PM
mopar65 Offline
mopar65  Offline
second pic mopar65
Re: another HHR fan question A Bodies ONLY [Re: mopar65] #437033
08/15/09 02:56 PM
08/15/09 02:56 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Mopar65 - thanks . I had no idea the motor is offset on the Taurus fan .
what is the distance from the Rad fins and the edge of the factory water pump housing ? did you move the rad ?
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437034
08/15/09 09:33 PM
08/15/09 09:33 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Ford taurus fan is 4.85 thick pulls about 30-35 amps on low about 50 amps on high
Re: another HHR fan question A Bodies ONLY [Re: gtx69] #437035
08/15/09 09:41 PM
08/15/09 09:41 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Am I the only one who mounted my rad in front of the core support?
BB, TT5,Procharged 3300lb Street Car 4.79/154
