Re: Choke issue on small block 340 w/ Holley 650 man.ch
[Re: PAULS_340]
#436655
08/13/09 01:16 PM
08/13/09 01:16 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""when I physically close the choke the car really smokes and coughs when it starts...why?""
Black smoke would indicate that the choke plate is closed too far. The choke plate limits the air into the carb which equals richer which equals black smoke. Adjust your choke linkage to allow a larger air gap when the choke is applied, or don't close the choke all the way in warmer outside temps. This will allow more air into the carb. The colder the outside temps the more you want to close the choke plate.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#436656
08/13/09 02:14 PM
08/13/09 02:14 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Actually, that's exactly what was happening when the flap was completely closed. The main issue is I have an NOS '71 choke (spring action) for a Thermoquad and running a Holley carb. I should make a new arm to allow it to work. Thanks
Still looking for LM29H1B415501, '71 Demon 340
[Re: PAULS_340]
#436657
08/13/09 03:43 PM
08/13/09 03:43 PM
RapidRobert
A divorced choke means that the thermostat itself is seperated (it's in a well in the intake). A ballpark baseline is to adj it to have the choke plate lightly closed all the way @ 70 deg F then when it starts the choke pulloff must immediately open it a bit(eng vac pulls it open some) then the thermostat opens it up the rest of the way as it warms up
